chinesekiwi
- Feb 29, 2008
Hello, head-fi, I've got a little question that some of you peeps may be able to hopefully answer.
I just bought and paid-for some Head-Direct RE2's via Group Buy but however I am slightly concerned that the RE2's are 32 ohm IEM's while according to Cowon, the output power of the D2 is 16 ohms. Will this affect the RE2 in any significant negative way/ will an headphone amp be needed to counter this problem or isn't it a real problem?
Also I've read that the RE2 have a little problem with noise isolation. Are they as bad as say the Yuin's in terms of noise isolation?
And one last question for RE2 owners, how long did it take for your RE2's to arrive from head-direct (please state location)?
TIA.
TIA.
