AlanU
- Apr 20, 2015
Thx above. Headphones in use. 800s, 400i, grade 60. Asgard 2 , fiio 12 amp. My next move is a amp. To better. The Asgard ,800s pairing.
What DAC are you using? buying a Master 9 or high end dac will better your decent Asgard amp compared to buying a high end amp with mediocre dac. I'm still quite shocked how many here put emphasis on a amp more than a dac.
How you approach spending on your system is upto you of course
If you buy a high end amp that is great as it's part of the equation in great SQ. However like anything if you have a system with weakness you'll definitely hear the deficiency. A better dac with "good" amp will sound better !!!! Cheap dacs just sound average regardless if you use the best amp in the world.
I say the Headphones/speakers > DAC > AMP in how much impact the sound quality will change. Having all 3 as you max your budget will reap the best sounding (personal preference).
I still think the Hd800 (s) is an overly stimulating headphone for true chillout relaxation . However when you want the "detail" fix it'll deliver.
I urge you to test the He560. It's a noticeable step above the 400i in overall SQ. I'd rather have a decent amp and excellent DAC and use the leftover cash for a different set of headphones for a dramatic sound quality difference.
