Geek
- May 5, 2002
An IMPORTANT NOTE about the stock cable and replacement cables:
The fit even for the stock cable is TREMENDOUSLY TIGHT! I WAS TOO WEAK TO PULL THE STOCK CABLE OUT! I had to have my dad help me with that.
If you're not very strong, consider outside help if you also want a cable upgrade with the HD650.
Cheers,
Geek
Cheers,
Geek
