It's the midbass hump, recessed upper midrange, and early treble roll off that constitute my stance on these headphones. That soft fuzz (distortion)? throughout the frequency range only serves to accentuate these traits. |
Once again, I contend that this is an amp matching issue. I don't hear any of these things on my system. Midbass hump? Not there. Recessed upper midrange? Not there. Early treble rolloff? Don't hear it. Soft fuzz/distortion? Nonexistant.
Don't get me wrong -- I'm not just blindly sticking up for the HD600 because I own them (that seems to happen a lot in the world of audio). I own lots of cans, and I'll point out their faults without hesitating, because in the end what I'm after is the best sound. What I'm saying here is that a lot of these "faults" of the HD600 I no longer experience since getting the Max. And, granted, the Max isn't the cheapest amp out there -- but it's a very GOOD amp that is very neutral and has a lot of power. So if a very neutral and powerful amp drives the 600 without any of the flaws described above, that says more about other amps than about the HD600, objectively.
I think the veil is a good way of describing it. I hear it. In fact, I don't think its presence is debatable. The right electronics go a long way, but can't eliminate it IME. My biggest beef with the HD600s is the lean low end, though. |
Well, I'm debating the veil
I don't hear it. It simply doesn't exist on my system. And there is no "leanness" in the low end when they are driven by the Max. Again, I contend that a lot of this is the amp. From your profile, it looks like you're driving them with the MG Head. The traits you're attributing to the HD600 ("a veil over the detail" and "lean low end") are pretty common tube amp criticisms, and common criticicisms I've heard of the 600 by people using an MG Head.
And to say this "veil" or "dark" characterization is not debatable just doesn't hold water after reading this thread. Some people have that opinion, others don't, and the biggest contributing factor seems to be the amp (or the frame of reference).
So what I'm getting at with this thread is a more accurate characterization of the HD600. I feel that we should move away from generalizations like "dark" or "veiled" and move to the more accurate observation that the HD600 are pretty darn difficult to drive, and some amps just don't do it well (or some drive them "well" -- like the MGHead, which gives them a great midrange and makes them quite enjoyable to listen to -- but don't resolve bass and detail as well as others).
