elnero
And how exactly did you manage to hear a 10Hz tone?
Originally posted by aerius Wait'll you drive them with a Gilmore Class A amp. I plugged my 580's into the mint tin Gilmore amp that I'd just built up and the bass will pressurize your eardrums. The double kick drums on "Slayer" and "Metallica" songs sound absolutely huge and go deep down with lots of slam. When I played the opening part of "Liquid Diamonds" by Tori Amos I could practically feel my head vibrating from the strong 20-30Hz tones. Play that song on a set of speakers and you'll see the woofers move back & forth a good 1/2" at normal listening volumes while everything in the house starts shaking. So no, you're not crazy or losing your mind. |
Originally posted by Geek elnero, At a Meat Beat Manifesto (experimental electronic music) concert a few years ago, the whole audience suddenly scrambled for the outhouses after the group started playing-- the speakers used were accurately producing sounds extending to that low end you refer to. Ouch! |
"A 7Hz tone of sufficient amplitude can crack the walls of a masonry building and can affect a phenomenon known as brain entertainment whereby normal brainwave frequencies are reclocked and vital rocesses are catastrophically disrupted. Individuals, thus 'down converted,' usually die within seconds, though not before experiencing cruciating pain as internal organs are literally churned by tsunamis of air. Terrifying indeed." - Dan Sweeny, WSR v6 n1 issue 32 " |
Acoustic, Infrasound. Very low-frequency sound which can travel long distances and easily penetrate most buildings and vehicles. Transmission of long wavelength sound creates biophysical effects; nausea, loss of bowels, disorientation, vomiting, potential internal organ damage or death may occur. Superior to ultrasound because it is "in band" meaning that its does not lose its properties when it changes mediums such as from air to tissue.By 1972 an infrasound generator had been built in France which generated waves at 7 hertz. When activated it made the people in range sick for hours [23,302,546]. |
Originally posted by aerius Wait'll you drive them with a Gilmore Class A amp. I plugged my 580's into the mint tin Gilmore amp that I'd just built up and the bass will pressurize your eardrums. |
