hwc
- Sep 26, 2006
Looks good! Excellent job. I started with a big round circle of foam in the center, but I think your approach -- using strips of foam -- may be even easier.
You can also put foam on the angled/curved surface running from the wiring connector around the edge. You just can't put it on the flat horizontal surface.
How does it sound?
Are the modding correct? I got foam from old earpads and cut it to stripes ang glued them in... |
How does it sound?
