chris.d.m.
- Apr 28, 2005
Hope to check out the Auteur soon.
HD600 has been a standard mixing and mastering headphone for a very long time.
One of the most "neutral" measuring headphones is the Audio Zenith PMx2. It seems like this would be worth researching if money isn't a concern.
I’m curious about this one.
Considering it’s price (not sure about its availability) it seems one should also seriously be considering the ZMF Auteur.
Which as I understand it, might be a very good mix consideration pair.
I personally will check out Sundara in a few days in the <500 category.
Might be a good HD--6xx alternative.
Soon to see.
I just received an Auteur.
I have a couple of friends who work with sound professionally. They ALWAYS mix on monitors...with the odd sneak peak via the HD600. Both of them have owned the 800 and both of them sold them off. Apart from being too bright in the treble area the real problem with the headphone, 800 as well as the 800s, is the dip in the uppermids. This can potentially pose a huge problem simply because you can’t hear when fx vocals turn sibilant.
This is easy to fix with EQ though - especially as the 800 comes with such low distortion numbers. Still wasn’t something they wanted to keep either for work or for play.
Btw, "flat" and "neutral" are obviously not "fun"!
Yes, it is fun to get work done accurately, absolutely . The compensation is quite extreme and what looks great on paper, is something the drivers need to deliver in practice. Frankly, no idea if they are even capable of delivering.Accurate = fun to me. And if the headphone is doing a good job of accurately reproducing what an anechoically flat speaker sounds like in good room, then that's all the fun I need! But I get yer point. Alot of content was mastered before "neutral" was discovered. And consequently may not sound best on neutral HPs.
May I ask, btw, what compensation curve was used for the above HD650 plot?
Great article, thanks for sharing! Unfortunately, I don't have any equipment here to measure it myself so I have to rely on what Sonarworks provides me with. With my limited understanding, I thought that the green curves of my 2nd chart exhibits the volume compensation required, to get the flat response (purple line in first graph).
