PiccoloNamek
- Apr 1, 2006
What about your own?
Originally Posted by Stoney /img/forum/go_quote.gif The best sound from the HD650 requires: foam removed great cable great amp, esp balanced |
Originally Posted by kwkarth /img/forum/go_quote.gif The difference between the 650 and 600 at the peak is only a couple of db. |
Originally Posted by Davesrose /img/forum/go_quote.gif Humm.....I see this forum still has the same debates! My take is that it's the same thing. Sennheisers don't have "slow" drivers....an instrument sounds like an instrument and is not "sluggish". Now the HD580 series was engineered to have properties similar to speakers or listening to a live event. Your upper frequencies (which are many harmonics) are attenuated. The "detail" (upper midrange) is not as pronounced as other headphones. Some people will like it and others won't. I personally prefer the HD650 to the HD600 for classical music. The HD650s are the best headphones I've heard for symphonies: they sound the most accurate for that setting. Steve Hoffman doesn't engineer classical music, so for his music, the HD600 might be more "accurate": there is not one golden mean. System only has so much to do with it. Every headphone has a characteristic that will either float your boat or not. Great amp and cable help enhance a sound signature. However, I found the HD650s don't sound as balanced with the foam removed. They seemed to lose a lot of extension foamless IMO. I think one of the reasons why the HD650 is really good for classical is that it has the most linear attenuation in its treble: even compared to the HD580 or HD600. That's what Sennheiser has been improving on....now either you like that or you don't |
Originally Posted by esuko /img/forum/go_quote.gif Coloration usually is a spike in frequency or in distortion response. Changing tone of particular instrument or voice affected by the problem region. Looking HD650 response graphs from Headroom you do not find either. |
They without a doubt will reveal more detail compared to the stock cable. |
Originally Posted by PiccoloNamek /img/forum/go_quote.gif Not really. I compared them with mine and couldn't tell the difference. Exactly what about silver will cause more refined edges? Just because silver is a shiny metal doesn't mean it will make your headphones sound any shiner... true, silver is more conductive than silver, but I don't think this matters much when transmitting only audio information. (If you couldn't tell, I am a huge cable skeptic.) |
Originally Posted by tourmaline /img/forum/go_quote.gif Ever heard a really good electrostatic system? I think these are even better then a dynamic headphone in that respect. They lack the drive and musicallity, but have more distinct detail. You can easier disect an orchestra with an electrostat then with the hd650, the hd650 has a more musical representation with better tonal accuracy. Electrostats sound light in that respect. |
Originally Posted by tourmaline /img/forum/go_quote.gif I see you use the silver dragons on the hd650. They without a doubt will reveal more detail compared to the stock cable. It could be that the smearing isn't as apperent with the silver dragons. Silver cables in general have more refined edges compared to copper cables, it is in the outer edges smearing is heard, can be detected. |
Originally Posted by esuko /img/forum/go_quote.gif Hello Gurra1980 HD650 realy colored headphone? Coloration usually is a spike in frequency or in distortion response. Changing tone of particular instrument or voice affected by the problem region. Looking HD650 response graphs from Headroom you do not find either. Actually HD650 is well behaved headphone and it's frequency response imitates quite well total radiation response of a speaker in a room. Most recording engineers mix music for speaker listening and HD650 has a nice frequency response that in mind. If someone has insight to this HD650 coloration please do not hesitate to response. |
Originally Posted by Gurra1980 /img/forum/go_quote.gif To me the graphs of the hd-650 is quite spot on though, with big dips in the treble that takes away the treble texture of for example female vocalists and violins and I guess this gives them the fat, smeard, veiled, call it what you like sound (For the record I don't hear this smear in the natural sounds around me, so yes they are truly colored). |
Originally Posted by Gurra1980 /img/forum/go_quote.gif Yeah I also like to look at those graphs, and they can give you a little picture about how a headphone sounds, but it is very hard to do great headphone measurements because they sits so close to the ear drum, so everyone will hear different. The sound will not be transported through the air as with speakers, you can't adjust the distance between the headphones and you as you can with speakers, therefor a flat freq on speakers is almost always more correct. To me the graphs of the hd-650 is quite spot on though, with big dips in the treble that takes away the treble texture of for example female vocalists and violins and I guess this gives them the fat, smeard, veiled, call it what you like sound (For the record I don't hear this smear in the natural sounds around me, so yes they are truly colored). Remember that this is in my opinion, to my ears and I just write what I hear, this is not a flaw it's the carracteristics of the HD-650, which is my second favorite headphone, I like something in between the little to smooth HD650 and the trebly (is that a real word? ) Beyers, Grados. |
