Thanks, I'm reading now. I do have one question which hasn't been brought up as far as can find. The Modi Multibit is a 16bit dac which takes 24 bit data. How does it reduce a 24 bit file which say has 18 bits resolution down to only the 16 bits with out noticeable degradation?
I may not be 100% correct on every little detail but I'm pretty sure it works like this:
All of the Schiit multi-bit (R2R) DACs t̶r̶u̶n̶c̶a̶t̶e̶ round all the Least Significant Bits (LSB) of a 24-bit signal that they cannot natively process into the LSB that they can natively process.
Modi MB and Bifrost MB = 16th bit, Mjolnir = 18th bit, Yggy = 20th bit.
But what you have to keep in mind is that anything below @-60dB (10 bits) of audible signal is just mainly noise floor and quantization noise and doesn't contain any real musically relevant signal at all.
So by t̶r̶u̶n̶c̶a̶t̶i̶n̶g̶ rounding a 24-bit signal down to even 16 bits, you really aren't loosing anything of any audible significance.
For a really good and simple explanation of how bit depth and quantization noise effect sound quality, I recommend watching this video:
Edit: Changed 'truncate' to 'round'.
