lentoviolento
- Feb 17, 2017
how the **** can i set the mimby to upsample apple music? is it really useful anyway?
I mean they really are. The DAC chips themselves.
Atleast in the same tier.
Like ESS 9018,AK 4490, PCM5102A, CS4398...
They are all top end chips and all capable of the same thing and for the most part they resolve the same when implemented properly.
Usually what is better is the analog stages and the clocking (for DS implementations).
I can tell you that alot of the difference in sound is the tuning done by the manufacturers.
Those with more experience or knowledge will make better sounding products usually.
But hell, today in the world of cheap ICs you can get amazing quality for a low price.
I know that growing up I saved up for "good" sound cards and better speakers and now the FiiO K1 sounds better than everything I had as a kid for a fraction of the price.
So I'm not saying to not buy good stuff, or that nothing but cheap parts are worth it. This is mostly a hobby after all and you should buy what makes you happy and what you think sounds good.
If you wanted to bypass the onboard upsampling of Mimby, you would have your player software upsample to 24/176.4 or 24/192. I prefer letting Mimby do the upsampling but others prefer doing it in software.
DACs using the same D/A chip often sound vastly different. There is a lot more to a DAC's sound the D/A chip chosen. Also, Sigma Delta DACs are quite different than Multibit/R2R DACs. They are not even close to the same. You are making statements that are nonsensical!
I remember Mike saying there is no way to bypass Mimby's burrito filter, isn't it the same with its internal upsampling?
Mike said that....and then I asked about it as I described above...and he said that does indeed bypass the mega burrito filter.
So you're saying if I were to use HQ player to do upsampling to 32/384 khz, it would bypass the mega burrito filter and mimbys own internal processing?
Yes like I said its all about the analog portion of the DAC after the DAC chip itself.
Between the Op Amps, Filters, Thin Film Transistors, etc
Thin Film Transistors?
Wouldn't have thought a display would be described as the "analog portion after the DAC chip itself"
I guess you didn't really read far.
Thin Film Transistors can be turned into a display, this is one of the applications of them. But they are used in many applications, literally a 1 second google query provides me with this:
http://ieeexplore.ieee.org/document/5458036/?reload=true
