Porteroso
- Oct 29, 2011
My understanding is that the digital audio protocols (i.e. the protocols used between source components and DACs), including usb audio, do not do re-transmission.
No they do not. But USB protocol has re-transmission period.
USB will not correct any mistakes in an audio feed, which is the main point here. So yes, anything that causes an actual error in the transmission of 1s and 0s will result in an error being fed to the dac.
edit: Just to clarify, a thing that resulted in an error would almost never be a one time event. Things of that nature are present the entire time your equipment is setup the way it is. So the result would repeat itself, probably predictably. And if your dac is being fed predictable errors, it would manifest itself in a way that might certainly be audible.
Most of that would be the result of a terribly made USB cable, which there are many of. But USB implementations, especially in laptops, can have issues of their own.
Anyways, to make my point, I don't want to argue with you, but if most people run their fulla or whatever it is that you have on their desktops just fine, and it doesn't work in your 2 laptops... it might be your 2 laptops. And schiit cannot make products at their price level that do everything. They have made a fulla, which works well with anything feeding it a good signal. If your laptops are feeding it a bad usb signal, they have something for that too, to clean up whatever is happening.
My advice is, if you want to continue to schiit on schiit here, in one of their (many) little fanboy threads, buy a wyrd, and if it doesn't clean up your usb issues, continue to schiit on them. But if not, please, don't take a schiit on a product not related to this thread (the modi thread btw), that is designed not only on a performance basis, but also on a value basis.
