Thanks, I'm going for Multibit then!
I have one more question before pulling the trigger:
Anyone using Optical (Realtek's optical output more precisely) can digital control the volume level via windows shortcuts/windows general volume mixer?
I've never used optical and I'll probably use it with this DAC.
The explanation of this question is:
My setup would be:
[ PC (USB or Realtek's OPTICAL output) --> Modi Multibit --> RP6G3 monitors and currently the volume is near the min level: -30dB ]. To control the volume level I use my
PC's keyboard shortcuts. (As well as a remote control with the same shortcuts, etc).
But yesterday I've learned that you can't control the volume using USB input in this DAC: (Schiit's support said to me: [COLOR=212121]
USB is usually fixed level on our DACs). If this means that I can't control Windows volume, I'd like to know if you can do that finely using the Optical output.[/COLOR]
In other words: I want to be sure that I can decrease the volume with this via optical cable:
Thanks!
