kennyb123
Sure. I did a search for question marks and only found two questions from you.Do you have an answer to any of the questions I posed above?
"then how do we explain DSD sounding different?" Because something about it is different. I can't think of a DAC on which DSD doesn't sound different from PCM. I think it's partly due to noise and partly due differences in how well each format preserves transient information. The experts don't even agree on this so why in the world would should we expect amateurs to be able get our heads around this? I think it would take a very solid understanding of how we our hearing works to understand what's important here.
"Does the process of PCM to DSD conversion have some inherent flaws that alters the original data or does the fact that the DAC is working with already-broken-down data have an effect on what happens inside the DAC, despite the main stages of its conversion seemingly being almost identical (I'm saying "almost" due to PCM de-emphasis)?" I have no clue. The flaws can be much greater upstream though. A noisy server or a noisy network screw things up far worse.
