Please, a screen shot of your settings would be ace if you don't mind.
I would like to try them all out thank you.
Sure, that's the first setting that I've been so happy with that I've stopped testing others.
Of course, for any particular genre or even a particular song, it's always possible to find a different setting that will suit it best. And this will, of course, largely depend on one's preferences. I think that if one is after sound that is as "full" as possible and is prepared to give up some of the depth, then the Sinc filters might be a better choice. I was initially a big fan of the Sinc-L but every time I use it now I just know how much of space/depth I'm missing and end up going back to the above.
It must be taken into account that both my headphones are known for their spatial presentations (the Utopia - its depth, the HEKse - overall stage size) and this effect might not be that pronounced on other gear.
The fact that Jussi, the HQPlayer's designer, chooses this filter as the best option and that Rob Watts has always said that if in doubt, the filter with more depth is the more "correct" one - makes me think that this filter is not only subjectively awesome but actually the best way of making 1s and 0s music again, currently known to us.
But as far as technical knowledge is concerned, my understanding of it is limited so I'm also looking forward to hearing more about your findings,
@taipan254 I think that overall it's a trade-off between perfect frequency response (high frequencies attenuation) and time-domain response. It seems that upsampling to very high frequencies allows for filters to be less of a trade-off and getting us closer to the original sound (even correcting the A->D conversion error via apodising). I have enjoyed experimenting with different filters, from Roon's internal upsampling to Sinc-M, Sinc-L etc. but the settings shown in the attached photo are the only ones that make me go "OK, this is a clear step-up in quality".
And regardless of what filter I use, my DAC always benefits from being fed DSD instead of PCM. Surely, it's nothing to do with the format as such - it'll be due to how those bits are processed inside the DAC when it's fed single-bit data as opposed to 16-bit blocks of data. The situation would surely be different in an R2R DAC which is designed with PCM in mind.
And of course the DAC is always in "NOS" mode
I can hear a big difference when this mode is off, even when the DAC is fed externally-upsampled signal. I think that this means that the DAC is still applying its own filters on top of everything else, which of course defeats the purpose.
I'll do some more listening using PGGB as I've not gone back to it yet. I so wish it also did DSD so that I could get the full benefit of it.
