Gustard X20pro DAC (ES9028Pro)
Mar 14, 2017 at 2:14 PM Post #106 of 294
Ampeezy
  The USB card by Gustard is small and fits in a slot. You would just need a Torx driver to open the case and back panel to get it in. I don't know what they would charge for just the card. This card does not do DSD512, which people say is the best quality. The XMOS chip used by Gustard is not the latest and greatest, so you might want to wait. Also their outboard converter doesn't have DSD512 or the latest XMOS USB chip.
The higher performance option is an outboard box that converts from USB to I2S or SPDIF coax. These usually have better clocks with less jitter.
When a good option for getting DSD512 happens, I'll go for it then. Right now, only a few guys have hacked together their own solution with much soldering and effort, and are very pleased using HQ Player to upsample to DSD512 compared to DSD256.
I was considering the same thing, and came up with this:
http://www.ebay.com/itm/172489899788
It also does up to DSD512. What do you think? and are there better options out there?
Mar 14, 2017 at 3:19 PM Post #107 of 294
markk02474
I've not really studied up on this all yet as the choices for DSD512 are still few.
The Gustard does have a funny problem with non-conventional wiring of the HDMI connector for I2S after getting it wrong for an older product and then keeping the same pinout for compatibility. You either have to custom wire a cable, or something like reverse audio polarity and swap L+R channels. Some discussion at whatsbestforum along with Gustard mods and tweaks.
Mar 14, 2017 at 3:59 PM Post #108 of 294
rafabro
Just simply buy Singxer SU-1 and forget. Very high SQ is more important than have or don't have DSD512...
Mar 14, 2017 at 5:22 PM Post #109 of 294
Ampeezy
​Yeah I was considering that, but I was under the impression that I2S is superior to even coax. The Singxer only has one coax output right?, if the LKS sounds anywhere near as good (no idea), then it wins just by the sheer connectivity options no?
Mar 14, 2017 at 11:07 PM Post #112 of 294
MINORISUKE
See my post with DSD512 photos in LKS USB-100 thread in Computer Audiophile.
There is also an instruction for HDMI LVDS wiring without soldering.
As for the sound, I prefer SU-1 for Windows (up to DSD256 at this moment) and USB-100 for Linux.
The internal USB card in my DAC-X20 has been taken out, as it degrades the sound quality even not in use. A choce without the card is clever.
Mar 15, 2017 at 4:01 AM Post #113 of 294
markk02474
Here is the USB receiver someone over at whatsbestforum got working in his Gustard X20 to do DSD512 reliably: http://www.diyinhk.com/shop/audio-kits/107-xmos-dsd-dxd-768khz-high-quality-usb-to-i2sdsd-pcb.html
There are many interesting products for sale on that site, like a ES9038pro DAC etc. kit for about $300 when the above USB to I2S and display are included: http://www.diyinhk.com/shop/audio-kits/120-es9038pro-xmos-dsd-dxd-768khz-usb-dac-with-bit-perfect-volume-control-and-spdif-input.html
I have ordered some very low noise voltage regulators from the site, and they came as advertised to me in the US.
Mar 15, 2017 at 6:57 PM Post #116 of 294
rafabro
I tested wireworld 7, Audioquest Forest, Cinamon, Carbon, Coffee + few cheap cables from ebay.
In my opinion AQ Carbon which I'm currently using, is the best value cable from SQ point of view. My friend bought Coffe set (+USB) and yes it sounds better (bit more smooth, gentle highs) but the price...maybe some day :wink:
Up to 1m long will be fine. I didn't notice any difference between 1 & 0.6 cables.
Mar 17, 2017 at 11:44 PM Post #117 of 294
Ampeezy
Anyone hear any difference with a power conditioner?
https://www.monoprice.com/product?c_id=115&cp_id=11512&cs_id=1151203&p_id=604830&seq=1&format=2
Considering getting this, and it does look very sexy i must admit
Mar 18, 2017 at 1:45 PM Post #120 of 294
rafabro
I wouldn't expect any miracle here. Try and return when no effect.
