Gustard X20pro DAC (ES9028Pro)
Nov 3, 2016 at 6:37 PM Post #5 of 300
IMO only against knobs are the holes from the top. If they turn them around 180 deg will be enough.
I like X20U style. But Holo Audio Spring looks more cool :wink:
Nov 4, 2016 at 6:04 AM Post #6 of 300
Is possible to upgrade from X20 to X20pro ?
Nov 4, 2016 at 3:52 PM Post #9 of 300
  why not go for 9038 directly the ess flagship
ah20 use akm flagship 4497. i just wish they replace it with 9038pro that will make more buyer
Chip doesn't actually matters so much. Most important (and I'm counting on upgrade) is power supply quality and USB implementation.
Currently I'm testing Singxer SU-1 with my X20U and this makes giant difference. This shows what really Gustard need to change in DAC. It is level up upgrade. Unbelievable!
Nov 5, 2016 at 10:57 AM Post #10 of 300
Im not sure I understand. What does the su 1 show that the Gustard needs to change?
Nov 6, 2016 at 5:48 AM Post #11 of 300
The sound quality improvement.
When you change this...
To this...
It is really wort to try, but even if you buy blind you wont regret.
After few days of test I already ordered my own. For Gustard sound quality is level up upgrade. Definitely wort the money.
Nov 14, 2016 at 1:35 PM Post #13 of 300
Just saw their preorder page. $829.99, shipped beginning 26 Nov 2016
