GuyUnder
AKA GUTB, mdavid
- Dec 19, 2016
@GuyUnder, is the top off the dac? That will cause the sounds you describe, if so put cover back on. Then what CPU are you running for 512, usually a under powered CPU will stutter. What is your connection between bridge and dac and length? Shorter better. 512 pushes this chip, any thing out of whack can cause noise. Good shielded connections, short runs be best.
The CPU is very powerful. Cover is on, but I'll experiment with cable length -- well shielded connectors I can't claim that I have. I would really like to make this work as I can hear the kernel of extreme clarity through the artifacts...
