Hi,
Thanks for all the replies.
Shenzenaudio did reply to me with a note that a 2025 battery should be used, since it is 0.5mm thinner than the 2032 maybe the cover will sit flush when it's in.
@Triplefun, thanks - I did download the ISO and will see how it goes.
@divinearun , the manual is on the USB stick, there's no printed manual.
@Ric Schultz, I did read your mod descriptions and they are very helpful, but I'm sticking to putting shields on the AC wiring and permalloy sheets between the transformer enclosure and the rest of the DAC. Stray flux fields are a problem, and we all know they couple through the current-carrying wires, and I hope to fix this through shielding. I cannot defeat the fusing or switching, as this unit technically belongs to a group of people and I am not going to always be able to control its environment or users.
Where I do agree with you is the output stage, Gustard didn't even bother to put in a Bal-SE converter of any kind, so the RCA outputs will continue to have very poor common-mode rejection. In a DAC this can be fairly significant source of distortion. The output stage is also needlessly complicated - they have I/V and LPF based on opamps, followed by a discrete buffer (that looks suspiciously like a power amplifier/diamond buffer design except with SMT components). The balanced outputs should be okay, except passing through such a long chain will not be a good thing.
I would personally not use transformers on the output of a low-compliance DAC like the 90x8 chips unless I was chasing sonics - and for that there are other, better candidates than any from the ESS stable.
Also the output stage negative supplies are derived from positive supplies and even though they have shunt regulators on both rails and local cap multipliers, I don't like supplies generated this way. Again, modding all of this is not on the cards at the moment but I do want to be seized of the design issues.
I see your point on the compensation but it's not a toggle (far as I know), it requires programming the DAC to match/compensate a specific output stage. At least that's what I make of it - could be wrong as ESS is quite short on technical detail on every feature. Hopefully it will mellow down with time - but none of the DACs I have exhibited that sort of behaviour. It was more about me getting used to the(ir) sound. Let's hope this one is different.
