trappedintime
- Aug 27, 2015
Congratulations in zeroing in on the Gustard
You won't be disappointed
The Gustard XLR output is 5.6v RMS for 0db (or so I have been lead to believe)
The liquid carbon has an input sensitivity of 0.775v for 0db
therefore you should reduce the Gustard output by -9db (every 3db halves the voltage)
The ragnarok
http://schiit.com/products/ragnarok
Assuming a 1v input sensitivity for 0db (gain - 1 mode) then the gustard should be set either -6 or -7db
At the end of the day, let your ears determine what's best
I don't believe that any settings on the Gustard will upset either of the headphone amps
Thanks for the reply. I guess I missed the specs on the liquid carbon's input sensitivity but I thought it was a little lower than the Rok. I'll play around with it, but -6 to -11db appears to be right in the wheelhouse. I'll post my impressions with all 3 rigs once I get about a week of burn-in.
