GoldenOne
have you tried measuring on audiophilleo 1 and2
and see what the result will be
I've not tried either unfortunately. I'd happily try one if the opportunity arises thoughGoldenOne
This is using the APx555's own 10Mhz reference output, with cables I've personally tested to be correct characteristic impedance.Hi @GoldenOne ,
May I ask what external Oscillator was used during these measurements? I find it strange, if the EXT XO is better (less phase noise) and with correct BNC connectors and cable, to get a worse result than on internal XO's. The Accusilicon AS338 are quite good compare to a lot of other XO's out there.. But by adding the highest quality master clock as in my case is the REF SE120, the result soundwise is brilliant.
-How can the measurements show these numbers?
/Jan
Good to hear this experiment. Something I'll do down the line. What bnc cable do you use? I experience the same upgrades using a ocxo. It's better than getting a dac upgrade. I have taken out the ferrite on the stock Elite as it gives a hump on the upper mids. Then I use a Oyaide dc plug. It's a great upgrade path. I have since upgraded the dc cable to silver occ for a deeper more extended top and bottom sound.I have tried different power supplies with my AD Double Crown Clock and each time I’m getting impression “my DAC was replaced” and not the clock LPS … The tone is different not just instrument separation and the stage … Most recently I tried iFi iPower Elite and got more bass and highs + more micro details… (AD Double Crown Clock is connected to U18)
I've tried the Titanis between the Zen Stream and different DACs fed with line conditioner, silver cables and 24x lt3045 voltage regulators. It has a thin sound. Lacks extension and mid bass. Ifi USb purifier 3 is a much fuller sound with no compromise.i have done it to put HoloAudio - Titanis, then idefender with xpower 5volt
the best clock, is mutec ref10
I’m using Gustard C2 clock cable ($167) and it seems to beat the stock cable (AD Red clock cable 1m) I will be ordering Farad Super 3 LPS soon I want to try it with the clock and I have 1 extra SR Purple Fuse available just in time. With the fuse and DC cable upgrades the price is close to $1K it’s a lot for a LPS but I think I’m going to do this…Good to hear this experiment. Something I'll do down the line. What bnc cable do you use? I experience the same upgrades using a ocxo. It's better than getting a dac upgrade. I take out the ferrite on the stock Elite as it gives a hump on the upper mids. Then I use a Oyaide dc plug. It's a great upgrade path. I have since upgraded the dc cable to silver occ for a deeper more extended top and bottom sound.
I've tried the super 3. It's a bit deeper (in a less transparent way, but more due to the caps) and slower than the Elite. The Elite beats the Hypsos in all my devices. Hypsos has a haze and is grainy + poor blacks in comparison.I’m using Gustard C2 clock cable ($167) and it seems to beat the stock cable (AD Red clock cable 1m) I will be ordering Farad Super 3 LPS soon I want to try it with the clock and I have 1 extra SR Purple Fuse available just in time. With the fuse and DC cable upgrades the price is close to $1K it’s a lot for LPS but I think I’m going to do this…
I'm using “Fanless” cheap mini PC with Linux based Daphile (Real Time Kernel for low jitter) powered with ifi elite at the moment and it’s a huge improvement over always noisy laptop I’ve been using before … Would you say Zen Stream is going to be cleaner due to that Audio USB port it has ?I've tried the super 3. It's a bit deeper (in a less transparent way, but more due to the caps) and slower than the Elite. The Elite beats the Hypsos in all my devices. Hypsos has a haze and is grainy + poor blacks in comparison.
Does that mean you have tried the c16 /c18 vs the AD ocxo with the u18? How's the difference?
No. I didn’t get a chance to check out Gustard C18 clock with U18 … I went with AD Double crown Clock and then just replaced the clock cable …I've tried the super 3. It's a bit deeper (in a less transparent way, but more due to the caps) and slower than the Elite. The Elite beats the Hypsos in all my devices. Hypsos has a haze and is grainy + poor blacks in comparison.
In a simple setup, coax sounds better. But I exceed the coax performance by doingI'm using “Fanless” cheap mini PC with Linux based Daphile (Real Time Kernel for low jitter) powered with ifi elite at the moment and it’s a huge improvement over always noisy laptop I’ve been using before … Would you say Zen Stream is going to be cleaner due to that Audio USB port it has ?
