Failed Engineer
- Apr 20, 2004
phile1, your instructions worked to install Chodi's WaveIO driver. Thanks!
Hi and thanks again for all the tips, I just ordered one of these... if anyone is using JPlay successfully can you please advise which driver ?
Thanks..
in response to BlgGear:
Yes, that is an “interesting device”. Would like to know whether the PFGA does reclocking. The XMOS is already capable of handling the USB side and in passing PCM and DSD data. The Musiland devices also use an FPGA, but they do not have an XMOS. I can see you’ve done extensive mods already…
In a way all devices that transfer data through USB do some sort of reclocking since the data coming through the USB has a different time domain. The Musiland reclocks the data with clocks generated by the FPGA clock management modules through clock division and multiplication and cascading. The XMOS reclocks the data by generating clocks based on its 400/500 MHz clock by “picking clock ticks that coincide with the external clock ticks”. It is possible that the Gustard uses the XMOS for its USB interface (and mature device driver) and the FPGA to reclock the data but based on simple clock division of external clocks rather than relying on its internal clock management circuitry. Based on most data sheets, the jitter originated from simple clock division is lower than the jitter originated from multiplication/division/cascading.
My U12 came in today and I believe with the latest driver on the disc [v 2.23]. I ordered from kiduit_online on amazon.uk
Will test the unit thoroughly when I receive the Gungnir [just sold my NFB-7]
USB 2.0, 24/192, Async, Completely Buzzword Compliant
Gungnir’s Gen 2 USB input is one of the most advanced implementations available today, featuring a high-speed USB 2.0 interface (not 1.1) and asynchronous data transfer to 24/192, including 24/176, based on the C-Media CM6631A USB receiver. No drivers are required for Macs, iPhones, iPads, and popular Linux distros like Ubuntu, and Windows drivers are downloadable for Windows 8, 7, and XP.
I was running JPlay with my Musiland 03's without much problems. But to get the WaveIO driver to install I had to uninstall JPlay. I still haven't tried to reinstall it yet. Just so happy with the sound of the U12 - I don't want to jinx it. Actually, I'm quite satisfied with the SQ of the U12 - it has a natural ease to the sound - like some hidden distortion has been lifted. For the first time my digital system is at a par with my analog one. I partly attribute this to the Gustard and a major part to the incredibly musical, transparent and dynamic LiteDAC60 heavily moded. Cheers to true R2R DACs and Mundorf Silver/Oil caps!
http://www.head-fi.org/t/740362/lite-dac60-pcm1704-r2r-tubed-dac-mod-project
Down the road I may give JPlay a try with the Gustard - when I'm in an experimental and patient mood. You know how temperamental JPlay can be - can you say 'bluescreen'.
Hi, many thanks for your driver config... I have been lucky with JPlay, for 2 years or so, no BSOD.. but I have a pretty simple server with just WIN2012 Server, AO, and JPlay.
I use the JPlay Mini ap in Hibernate mode and only play .wav files.
I like JPlay for the various engine/buffer options - and actually XMOS is pretty well received with some very low latencies reported.
Currently for DDC I am using a Teradak 9V 1A LPS powering an iFi iUSB ->adapter-> Wyred 4 Sound uLink (also XMOS).
It actually sounds great via BNC to a Audio GD NOS1704 DAC.. the ULink is rock-solid with JPlay..
Since the W4S SQ is rated a little below Audiophilleo, I am hoping the Gustard will be a step up, but mainly I am thinking to upgrade to a M7 DAC soon and so will ask Kingwa to match the Gustard HDMI pinouts.. (..I will wait for the Schiit Yggy reviews before pulling the trigger on the M7 though..)
Thanks again - if any other Gustard folks are using JPlay, please chime-in... in any case I will report back in a week or two with the Gustard to W4S comparison and also the Gustard driver JPlay compatibility..
