Gustard U12 USB Interface 8 Core XMOS chip
Jan 8, 2015 at 11:06 PM Post #361 of 3,701
Any news on that U12 vs. Audio-gd DI 2014 comparison?
Jan 9, 2015 at 6:09 AM Post #363 of 3,701
U12 should arrive any day now
Did you order inside EU?
Jan 9, 2015 at 11:35 AM Post #366 of 3,701
Anyone who wants to try an awesome interconnect cable - I highly recommend these Aural Thrills Silver/Teflon.  They use a unique grounding circuit and Teflon/Silver plugs similar to the very expensive WBT's.  $179/pr for 1 meter - 60 day free trial.  So you can do your own free 'blind test' after burnin.
http://app.audiogon.com/listings/interconnects-aural-thrills-audio-silver-braid-w-silver-teflon-rca-read-this-before-you-buy-2015-01-03-cables-75042-garland-tx
Jan 9, 2015 at 2:23 PM Post #367 of 3,701
^ well, with free trial... Gotta say that is fair! Of course, bias is still real :D
Jan 9, 2015 at 8:47 PM Post #369 of 3,701
I once read that 30% of pharmaceuticals benefit are from placebo effect - maybe a mind/body interaction,  I don't know.  But they sure work for me.
Maybe I can hire a hypnotist to in-plant my Nissan drives like a Porche.  Ever see the movie Shallow Hal
I also have these - a little cheaper, not quite as airy but really sound good.  $134/pr 1 meter.
http://www.ebay.com/itm/Aural-Thrills-Self-Powered-Active-Shield-Cable-1m-Silver-Teflon-Connectors-/251779920158?pt=LH_DefaultDomain_0&hash=item3a9f40b11e
These are their top of the line - not 4x better.  But better- especially with the right tubes (I can hear a difference in different tubes - Mullards are my favorites).
http://www.ebay.com/itm/Aural-Thrills-tube-powered-active-shield-300b-274b-kt88-home-theater-/251779919344?pt=LH_DefaultDomain_0&hash=item3a9f40adf0
Jan 10, 2015 at 11:17 AM Post #370 of 3,701
Dude - this is not a cable-discussion thread!
If you really must talk about how cables changes sound and so on - keep it to USB-cables (which could or could not make a difference to the Gustard U12)
Back to topic; I'm getting my unit on monday.Have been using a M2Tech for quite some time now so it will be cool to hear the difference!
Jan 10, 2015 at 12:24 PM Post #371 of 3,701
Sorry you are right - no more cable discussions here.  I will start a new thread on the Aural Thrills stuff.
Jan 11, 2015 at 12:23 PM Post #372 of 3,701
New to this thread and have just skimmed through it all... still having trouble wrapping my head around applications for U12 other than just providing USB conversion to SPDIF?  Curious as I just got a Gustard H10 amp and I am now considering a X12 DAC as well.
Do most of you look at something like the U12 because you have DACs that do not have a USB input, or do you look for even better USB performance from the U12 and then optical or coax digital inputs to your DAC?
I have a system scenario that I was wondering if some of you could help me with, deciding if the U12 is a good fit:
I have a medium sized basement family room, iMac based home studio on one wall, digital active stereo system on another, and then a listening chair with a headphone studio next to it on yet another wall.  I have a MacBook Air that I can keep near the listening chair, and planned on running USB into Gustard DAC and amp that I would also keep next to the chair.  About 10 feet away is the iMac on a desk and I would like to be able to use that as a source as well, so I was thinking about a U12 sitting next to it, with optical output running to the miniDSP 4x10 HD across the room that drives the stereo system, and then digital coax running along the other wall and into the Gustard DAC at my listening chair for those times when I don't want to bring the MacBook Air downstairs for whatever reason.  And then I have a separate USB feed from the iMac into the studio interface I use (Focusrite Scarlett 18i20) for times when I want to listen to headphones while sitting at the iMac.
Does this all make sense?  Would the U12 be a good way to feed USB audio into my miniDSP and also run to the X12 (future purchase, currently using NAD D1050 as a DAC)?  Kind of like a digital audio stream router?
Jan 11, 2015 at 1:05 PM Post #373 of 3,701
For me I'm looking for the best USB converter at reasonable cost.
Jan 11, 2015 at 1:09 PM Post #374 of 3,701
and is that because your DAC does not have USB input, or it does have USB and since it also has other digital inputs you are using the U12 because you think it is superior to yours DAC's onboard USB input?
Any feedback on my application scenario?  Does it make sense to use the U12 as a digital audio stream router?  Do all outputs work at once by the way?  Even without my family room studio scenario, it seems like it would be a cool way to review equipment, to be able to feed the same USB audio stream to multiple DACs at the same time.
Jan 11, 2015 at 2:37 PM Post #375 of 3,701
Well I have many DAC's - some with USB and others without.  My best DAC's do not.  I like the flexibility to change DAC's and USB interfaces separately.  If you read the thread starting page - I mentioned all the USB interfaces I have tried.  The U12 is the best sounding I have owned so far.
I'm not familiar with the U12 optical SPDIF, or HDMI, as I use the coax SPDIF only.  Maybe others can comment.
Good Luck!
