GCTD
- Apr 9, 2015
So how exactly does one run 32bit 384khz on Gustard U12? Mine only goes up to 24bit 192khz in Windows 8.1.
I'll be interested in your cable rolling results.
Yes you are correct on the PPA that is just the 24Mhz USB clock - but I believe it still gets reclocked by the Gustard U12 XO 24 Mhz. All the clocks I had shown were the 24Mhz USB ones.
One question if the stock USB 24Mhz XO clock in the U12, MX-U8, DU-U8 is femto level - what's the purpose of an OCXO in the PPA? Seems like $429 is a lot of money for not much gain? OCXO marketing hype?
From Uptone on the XO they use in the Regen and John Swenson's comments on the importance of the USB clock (not as important as the clocks that feeds the DAC - your 957's). So in light of that is seems the PPA OCXO is way overkill - but again this is all theory - what sounds best is what's important!
Of course the modders are already in action - got to love this hobby! Here is the mod Swenson refers to and the Neutron Star clock.
http://www.newclassd.com/index.php?page=36
I'll be interested to see the DC mod you re working on -that would be interesting.
Another solution would be to have Paul design a new ultra clean 115V to 9V power supply and feed that right into the U12's AC input lines. I thought of doing that with an R-Core transformer - but have not had time to mess with that.
The Breeze uses a 7.5V input
Pinout is not correct since U12 has LM317D2T (surface mounted).
I read some reviews about Belleson on diy fora, Belleson seems NOT to regulate as it should, it does filter noise but not regulate, so i am going for the NewClassD.
If you replace Philips (BC) caps 2200uF-25V with Panasonic FC 4700uF-25V like i did, then there's room enough for the UWB
You still have to bend the connections but it is possible.
As you can see, Input is the right pin and NOT the left one as showed on the UWB pic with normal LM317.
On the PCB you can see three holes at the LM317's left side, they ALL are connected with output, so you can use one of those to connect to UWB's output.
As ground you can best take -pole of one of the 2 Panasonic FC's
Btw, Voltage output of LM317D2T in my U12 is 5.1V
As you can see, i didn't fully cover the 330uF-16V caps with 3M stuff because we have to replace them with 10n (MKP)
when swapping the reg with NewClassD UWB,
well snap. I was putting some EMI/RF 3M film stuff on my U12 tonight and somehow caused a short and blew the transformer...time to convert it to DC now. It burned a hole through the board on the top primary connection. I plugged it in for all but a split second and hurt a fizzle. nothing else seems to be damaged.
That's not good to hear I suppose the best way to revive it is external psu. But, maybe it's an option to go the way of Breeze since it performs very good (as rb2013 says).
To connect Dexa, the pinouts are as showed in the dexa picture. The 10N MKP it's 10 nano farad and mkp is polypropylene film capacitor, wima is good.
So i am going to order an HDMI i2s output pcb from audio-gd and look into wiring it into a breeze in replacement of the rj45 port. Can someone show me a detailed photo of the rj45 port and how it looks inside the unit. It should be able to be wired up easily as its standard i2s input. And maybe, just maybe I will order a breeze if so.I like doing things custom and sounds like a fun project to try. Albeit the clocks in the breeze would likely be update to crystek 957 or 575z
But if they are 22 and 24's than maybe some femto clocks would be ideal.
Here you go - that would be an interesting experiment.
