rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
Hi rb2013,
regarding USB cables, you should try the Corning 3.Optical => http://www.amazon.com/Corning-Self-Powered-Peripherals-Receptacle-AOC-ACS2CVA010M20/dp/B00JOJRF6K
optical, thus no shield issue vs EMI/RFI.
I'm happy with it. Clearer sound.
And length is not a issue anymore with this cable : thus you can have a distance computer/DAC up to 30m, that's as good as if computer & interface/DAC was at 1m.
Rgds
Hi,
Much has been written on CA (this was all the rage earlier this year there) about this Corning3 Optical cable - with some reporting good sound and others reporting major problems with the cable. I get the theoretical 'optical isolation' deal - but that is just part of the equation. Most DAC's, DDC, etc.. have cheap electro-optical converters that run jitter level 10X to 100X spdif coax. Therein lies the problem - the communications indusrty (and defense) have very good electo-optical converters that are incredibly expensive.
From Alex at Uptone:
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/corning-optical-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-cable-experiences-23437/
Superdad
Music lover; Owner, UpTone AudioJoin DateApr 2008
LocationMariposa, California
Posts3,523
Remember gents:
Not only does the Corning USB NOT provide galvanic isolation (the 5VBUS is still sent), but there is either a USB hub chip, clock, and voltage regulator in each end, or a PHY, clock, and voltage reg. In fact I think you will find the cable shows up in the system as a logical HUB. The chip itself is likely a Corning design to integrate the PHY function with the optical transceiver.
So as with using any generic USB hub, you will hear a sonic difference. The question is whether it is a positive one or not. Of course there is such a thing as an optimized for audio USB hub coming, but I will restrain myself from shamelessly plugging such.![]()
The Corning Thunderbolt cable is a little more interesting to me, but for storage use, not DAC connection.
Edward, did you get your fiber-channel device yet? Can you post a link on the exact product? Was it an Adnaco piece?
Cheers,
--Alex C.
The secret sauce according to the Uptone folks was not the Corning fiber - but the use of a isolating reclocking hub - which the Regen was designed to the Uber USB Hub reclocker. Allowing the use of any USB cable including split power/data versions. So with the Regen/LPS in place the Corning 'advantage' is sorta mute, with the electo-optical converter in the chain as a disadvantage. But happy it's working in your system - it is better then the less expensive solutions like the Belkin Gold.
I tried to use Cornig cable with PS Audio DirectStream DAC, but could not get it to work. Anyone has any experience with it?
Speaking of split USB cables this one looks interesting for $200:
The Light Harmonic Light Speed 2G
http://marketplace.lhlabs.com/collections/cables/products/lightspeed-2g-usb-cable
