ginetto61
Gino, I am interested to know how you have come to the conclusion that toroidal power supplies are so bad?
I mean you can find them in gear costing tens of thousands of dollars. How on earth can they be such a problem if designers of cost is no object gear still use them? I'm not at all trying to attack you as you seem like a very nice and always polite poster here, but I'm not sure where the evidence for this dislike comes from? I'm no expert at all so perhaps there is evidence that they actually sound worse (not measure worse, I don't care about measurements that I can't hear).
Hi let me explain a little the rationale behind my suspicion about the use of toroidals for digital equipment power supplies
Usually when i am selecting a specific unit like a usb to spdif converter just out of curiosity i always look at the best ones in class, just to get an inea of their construction.
sadly their price is also high end and usually out of my budget.
From what i understand one of the very best in class is the Berkeley Audio Alpha converter here under depicted
http://www.computeraudiophile.com/attachments/f6-dac-digital-analog-conversion/9188d1385951024-15-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-spdif-converters-shootout-berkeley.jpg
if you look at its power supply you'll see that the designer has selected another type of transformer.
Without even thinking that would be my 1st choice for the voltage transformer.
Then i also had a look at their dacs, equally top class ... again no toroidals.
http://www.hifishock.org/galleries/electronics/berkeley-audio-design/source/dac/alpha-dac-1-berkeley-audio-design.jpg
i am quite sure that that kind of transformer can make filtering of mains noise less critical.
I cannot say for RF noise because i have no scope, but in a very rudimental experiment the spikes in the mains passes through toroidals in a spectacular way. No filtering at all.
A EI in the same position had a much much better suppression of these spikes (i.e. switching on/off of the lights in the listening room caused a loud noise through the speakers with the toroidals and much much less with an EI type transformer)
Both the x-former used in the converter and the EI type share the separation between primary and secondary windings,
I am not an expert but i think that measuring some kind of bandwidth the toroidals have a much wider bandwidth than EI type.
I read once that the toroidal construction could be interesting for output x-fomer in tube amps because of this. They let everything through.
Again i cannot say if the RFI suppression is of the same level, but i would tend to think so. I agree that if you have some kind of filter in front of the toroidal the final effect will be similar.
I will try a cheap RFI/EMI filter as soon as i will receive it.
If i had the money to spend i would buy immediately the converter above mentioned, confident to get one of the very best in class.
I also read other two interesting points in a review.
1) the designer of the unit, clearly a gifted one, recommends the use of AES/EBU connection with the dac. Needless to say that since then i am sold on this kind of connection and my ears say that it is indeed really musical. The sound seems more relaxed than with spdif while keeping all the detail
2) during the review different pc sources were used to drive the converter, from very cheap ones to very expensive ones. Even with cheap ones the sound was quite phenomenal, like it should with a very well design converter. It should stop the garbage in, use the signal and ouptut a very high quality digital spdif or AES to the dac. If a converter performance depends heavily from what is before is not a very good converter.
But you are right. The toroidals can be equally good. They will just ask for some more attention in the mains noise suppression department.
Like using a filter to supply the converter for instance. But i am honestly confused by the huge offer of different devices. I am quite lost.
To end i always look at the very best in class to try to understand what makes them the best.
Like in the Formula one when mechanics of other teams peep inside the box of the best performing cars to steal some technical solution.
Unfortunately my eye is technically quite blind.
Regards, gino
POST SCRIPTUM
actually thinking a little more and "stealing" this picture of the power supply in the very nice Tanly converter ...
http://gd4.alicdn.com/imgextra/i4/888047659/TB2xo9maVXXXXafXpXXXXXXXXXX-888047659.jpg
i can spot a choke and some caps after the mains socket upstream the toroidal.
Instead i remember the 1st version using a R-core transformer.
However ... given that the unit in question is said to be excellently sounding i have decided to take the external filter way.
I will look seriously at some DIY project for a passive main filter ... very simple .. just some chokes and caps and keep the U12 untouched.
But i am sure some kind of additional filtering for the stock unit will be beneficial. I prefer the Tanly PS for this aspect.
It is true that also high end units use toroidals, but they have all some kind of additional mains filtering in front of it (or maybe after ?)
Thanks a lot again for the very useful advice.
