b0bb
- Oct 15, 2014
Use another method to draw extra power from the amp , EQ is an easy method.Hi @b0bb, thank you for your suggestions and advises! I really appreciate them.
Problem with no sound after power up resolved itself after few days... hmmm. will see what will happen.
Epcos capacitors are by customs now and I'm waiting for delivery.
I'm not after Harman curve, I find it to bass heavy and unresolving. Qudelix5k has support for EQ and autoeq tried it and disabled it. I'm trying to avoid EQ when possible. HFM Arya FR curve is not prefect but I like its sound from H20.
Now I'm listening to OP1656 OP AMPs and trying to make my conclusion on it It sounds different that default OP AMPs.
That said the Kalimba DSP is the Qudelix5k is not doing proper justice to AutoEQ, it is a 15 year old, low cost consumer grade design Qualcomm recycled from CSR.
It has none of the modern high performance DSP features like vector processing (AVX, Neon) and fused-multiply-add optimizations and is quite slow at 100MHz, tops out at 64 MIPS
Qudelix made mattters worse by making the 32bit device work on 64bit data so it 2x slower than normal, this limits the amount of processing it can perform.
Not surprised at the unpleasant outcome you experienced.
If you are willing to try again, a modern PC. with the proper DSP software gives a better account of AutoEQ's capability like convolution, it is miles ahead of a simple ParametricEQ's capability when provided with sufficient computation resources.
It opens the possibility to add a GPU to bring thousands of high-speed processing cores to the table.
