Gustard H20 headphone amp
Jan 21, 2019 at 3:55 PM Post #346 of 646
Huh, interesting. Mind opening it up and taking some pictures?
The voltage selector is located outside the casing where you swiths either to 115V or 230V.
Took a short hearing and playing with gain. Definitely there is a wider soundstage on Top Gain but level db is same to me.
So far I have put in a silver fast blow fuse in it, Will switch to SS3602 or Burson V6 this weekend after some burning time.
Jan 21, 2019 at 7:21 PM Post #348 of 646
Hm, that didn't work. The corresponding email notification contains two "View attachment ..." links, but they don't work, either.
Yup, it doesn't show..even though I uploaded.
Jan 21, 2019 at 7:21 PM Post #349 of 646
The voltage selector is located outside the casing where you switch either to 115V or 230V.
Jan 24, 2019 at 10:57 AM Post #350 of 646
Mid way through burning. Remind me of H10 with V5 but with wider soundstage. H20 still on stock opamp though:ksc75smile:
Jan 25, 2019 at 1:14 PM Post #351 of 646
Waiting for your impressions! :gs1000smile:
Undecided to jump on these or the Liquid Platinum.
Jan 26, 2019 at 1:46 PM Post #352 of 646
10 hours into SS3602. From my Ares DAC balance into H20. Decide to take out my HD700 for a spin on it after a hiatus.
First using SE cable on (H) then switch to 4 pin XLR on HD700. Big difference in sonic changes . Well to my ears only :)
Compare to stock opamps. More separation details so far BUT stock opamps sound smoother to my ears....haha.
Ok, I know the excellent opamps of Burson V5i,V5 V6v V6c. I have them in my other DAC and 1 in my power amplifier and Burson Lycan . Will switch them as soon as Andrew reply me whether his opamps need to burn-in :)
Jan 26, 2019 at 2:25 PM Post #353 of 646
Thanks bro for the update!
Yeah waiting.
If I am gonno jump on these, hopping to have some inputs also on what possible upgrades I can throw at it.
Have a nice weekend!
Jan 28, 2019 at 12:24 AM Post #354 of 646
Can those people here already own and have H20. Can you post your volume mark ( O'clock) on your listening level with which type of headphones and it's impedance at which output?
Maybe I'm getting deaf, my 300ohm ZMF planar listening level it at 3-4 o'clock. Same as my Senns HD700.
Jan 28, 2019 at 3:05 AM Post #355 of 646
The only high impedance headphones I've got are AKG K340 and trying them I'm listening at 2 o'clock unbalanced...for reference I listen to audioquest highthawks at 8 o'clock balanced.
Jan 28, 2019 at 5:32 AM Post #356 of 646
You need balanced connection (gain -standard) for any harder to drive HP...Volume @ noon for LCD-2 ,all them 1/4 jacks are for low impedance HP
Jan 28, 2019 at 7:08 AM Post #357 of 646
Yes I'm using 4pin XLR balance exclusively.
Jan 28, 2019 at 7:13 AM Post #358 of 646
Ok thanks, likely change to Burson V6 this weekend and gauge my comfort listening level and compare to SS3602.
Jan 28, 2019 at 7:44 AM Post #359 of 646
Looking forward to your impressions.
Jan 28, 2019 at 11:18 AM Post #360 of 646
I listEn to my hd800’s balanced rarely past 2:00 and that is really loud! Love my h20!
