ansi
- Dec 3, 2014
I've done blind tests with cables that are a dollar, and those that are a hundred. Can't hear difference with any gear and I don't know anyone who does. Based on that experience, I agree with science - no difference. If you bought an expensive cable and think it sounds better, great. Don't do a blind test and enjoy the placebo effect.
DAC will re-clock the data, no need to worry about jitter from the computer. I think the quality of the USB cable doesn't matter beyond a dollar or so.
Hello sorry to ask redundant questions, but I'm totally unfamiliar with how power cables and power stabilizers or whatever can improve sound quality (funny thing I've never heard these concepts mentioned at all at the two head-fi meetings I've been to). But anyway, would a power cable technically be able to make a difference - considering that the on the other side of the outlet is connected to common household wiring behind the wall? Or maybe that's what the cable is for, to refine on that standard signal flow. And the big question here would be - were you able to notice any audible difference when using this power cable versus the stock cable (cable swap only directly to the wall).
For me I would probably just buy a padded power cable and not the surge protector. Perhaps I would use it for my DAC instead of the amp (Hmmm??)
Regarding usb cables: I guess many here use a computer (or similar device, none of which are my preference)* to play their music files, and feed the signal to an off-board dac.
So (I'm going break my own rules and start going technical), this means that you're playing (feeding) a live signal, which includes the time domain, through a usb connection.
If it was just raw data, like moving a file, it wouldn't matter. But as the file is being 'played', even though it's still digital, this adds all kinds of other complications (of which I struggle to understand; it's all about jitter and stuff!). But basically, in this situation, the quality of the usb cable does matter.
