spaech
- Jan 23, 2007
Wow - that was quick. But how does the power at 1Khz (the usual reference point) into the given load (300ohms) translate across the whole spectrum? I.e. what if at 300ohms one amp puts out xxma but at 5khz puts out yyma into the same load? Think that's more the question. You're extrapolating based on the one data point (power at 1kHz) and assuming it's flat right on through the rest of the spectrum. That's not what most are finding when the describe the H-10 as warm and detailed, and the BHA-1 as on the brighter side.
Well according to the impedance graph for the HD800, the difference in impedance between 1khz and 5khz is negligible, so power output should be almost identical. But there might be more to it that I'm not understanding.
