GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Nov 5, 2022 at 7:57 PM Post #1,171 of 9,976
Try writing Gustard at: Gustard@163.com
On another note. This I saw in their Taobao store. Guessing same functionality, different DAC Chip.
That looks so much better than the R26 design...
Nov 5, 2022 at 10:05 PM Post #1,172 of 9,976
I've now written to the address you gave above, thanks for that info mickey. The US price of the DAC you showed there would be about $1020 US, so looks like something positioned below the X26 possibly (?) with AKM chips instead of the ESS 9038s in the X26. A progression of the A line?
Nov 6, 2022 at 4:02 AM Post #1,174 of 9,976
Could you power off completely the R26 (with the front banel button and with the back panel switch) and then switch on only from the back panel switch (to put it on standby mode) and tell us if it keeps silent in stand by mode?
Thanks!
I received a new unit of r26 4 days ago, no hum, hiss, buzz or high pitch noises in any mode, i am using 220v and from India if that matters.
Nov 6, 2022 at 4:15 AM Post #1,175 of 9,976
Placed an order for Gustard R26 and LADDER Schumann
A blind purchase based on reviews and feedback is more of a desire to get to know the devices than an attempt to replace something in my system. But who knows.
Nov 6, 2022 at 4:21 AM Post #1,176 of 9,976
Thanks for the info! My unit was completely silent too in any mode in the very first days of use but now it has the high pitch noise issue only if I put the unit in stand by mode coming from completely switched off.
Nov 6, 2022 at 5:01 AM Post #1,177 of 9,976
I'm on 230V but my unit just have a slight high pitch noise coming from the front panel, not hum. And the issue only appears when I put the unit in stand by mode and just after been completely switched off from main button at the back panel. If I put the unit in stand by mode after the unit has been powered on there is absolutely no noises.
BTW the unit is always absolutely silent while powered on.
Same here from the beginning (4 months ago). Pretty harmless since only in standby mode, barely audible for me, not an issue for me (powered off the unit few times due to rearranging the gear, same outcome)
Nov 6, 2022 at 5:11 AM Post #1,178 of 9,976
Yesterday I have done a test and no problem. No noise. Whether in I2S (cd player) or coax (network player) it's ok
Nov 6, 2022 at 7:50 AM Post #1,180 of 9,976
Is there a firmware update funtcion over ethernet? Or do i have to use a usb stick each time?
You have to burn image using PC every time or if you have Linux expertise just ssh into it and run apt upgrade.
Nov 6, 2022 at 12:39 PM Post #1,182 of 9,976
Thanks!
It doesn't. When I power it on again the sound comes back indeed. Then it goes slowly away.
Nov 6, 2022 at 2:04 PM Post #1,183 of 9,976
Nov 7, 2022 at 2:11 AM Post #1,185 of 9,976
so I can't even use my Mac to put the firmware on a stick?
If you look further back at my postings I had to use my MacBook to successfully flash the 1.3 firmware using Balena Etcher.
