bluex
- Aug 14, 2016
IBasso d16 taipan it's an amazing piece of gear.Ah okay, I didn't realise they did that.
When I hear Ibasso I think of Daps.
iBasso d16 taipan is not even cheap mammia.
You can still connect your R26 via Lan.
If that is not possible, there is also a Lan to wifi adapter.
And then you have to connect to the streaming provider.
I think it's Sqeezelite or something like that, where you then enter your streaming provider login data.
But I can't remember exactly how that was, maybe someone else knows.
Otherwise you only have a laptop or PC as an alternative to go in via USB.
If nothing helps and everything is still the same and it worked before then a new flashing would be an option.
How else can I connect to the USB C ( tablet ) on R26?
i2S to USB C??
