I thought you meant that, thanks for clarifying. Interesting. R26 can sound very good indeed via its internal HQP NAA renderer, especially with as low noise a LAN as one can manage, it easily resolves every even minor network tweak I’ve made. Even better with super clean power, better grounding and a bit more RFI shielding if you’re so inclined.What I meant there is
HQplayer + Roon via LAN is better than DMP A6 which is better than just using upnp, Spotify or tidal streaming via LAN.
Btw for those using Roon remote or other control apps whether for the R26 or other streamers, once your system gets sufficiently resolving the device used as a wireless remote, and how it is used, makes an appreciable difference. I posted a few weeks back about it over on the Roon optimisation thread. Not just me, some Roon users over at the What’s Best Forum also concluded the IPad Air 5 is the best sounding device they’d tried as Roon Remote. Same held true for me with BubbleUpNp and JPlay direct to the R26, as did my other observations re damping and airplane mode etc. Give it a go.
https://www.head-fi.org/threads/roo...-increased-sound-quality.968792/post-17998421
