Thanks mate! appreciate you all for the help. I use Tidal also, but mostly Qobuz. Tidal is good for some vocal recordings, but I listen to classical music a lot, and Qobuz seems quite a bit better in streaming classical music.Actually I did have one more suggestion, in case no one else had made it… using @wikaudio ‘s modified Gustarender firmware with Tidal Connect it works smoothly for most who’ve tried it. Especially the pared back sans-Roon versions which might use less of the R26 renderer board’s tiny memory. But then I saw from your post above, Murphy’s Law, you are of course a Qobuz user so once more not a particularly helpful suggestion for you (assuming you don’t also have Tidal). We are trying our best though!
GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
- Thread starter m-i-c-k-e-y
I use Windows to stream in a way nobody I know of uses. I use Fidelizer together with Foobar2000. I don't play direct from Foobar2000 though, I install uPnP component and use BubbleuPnP to stream to Foobar2000. In the background, I also have Audiophile Renderer running, but I don't use that. Having Audiophile Renderer opened in background however will add some nice favor to the sound, don't ask me why, I have stopped questioning logic since I played with CAS.Ok, well good to know you’ve tried it, anyway. I’m all out of suggestions sorry given you don’t want to use a computer and the likes of Roon. I use Roon & HQP btw, smooth as silk even at the crazy high bitrate of DSD512. (Though what is your Windows ref above?)
The phone I run BubbleuPnP on also affects the sound a lot. All iPhones do not sound good, different Android phones also sound different. Phones with Snapdragon CPU generally sounds better than other CPUs. I personally use Samsung Note 20, I haven't found a phone that sounds better in uPnP yet, even my newer zFold 5 does not sound as good.
The above refers to my main system, which I uses U18 feeding to X26 Pro. I have no problem on my main system, the sound is superb. On my secondary system, I am trying to make the R26 sound close to my main system, with just a network cable.
Does anyone know if anyone has done any ‘inter sample overs’ tests for the R26? I’ve so far been using exclusively in fixed (full) output as I’m using a quality external preamp. I have just this week set the output the -3db. Would I expect it to handle overs better set like this? I havnt noticed any difference either way to be honest, but it does have the advantage of putting the preamp volume control in a more usable range.
Any thought?
Any thought?
sajunky
Setting pre-amp - 3dB doesn't help, as distortions are produced earlier (during oversampling).Does anyone know if anyone has done any ‘inter sample overs’ tests for the R26? I’ve so far been using exclusively in fixed (full) output as I’m using a quality external preamp. I have just this week set the output the -3db. Would I expect it to handle overs better set like this? I havnt noticed any difference either way to be honest, but it does have the advantage of putting the preamp volume control in a more usable range.
Any thought?
However when you play in NOS mode, there is no intersample overs, so no need to worry.
Right, thanks- thought as much.Setting pre-amp - 3dB doesn't help, as distortions are produced earlier (during oversampling).
i don’t use NOS mode so guess I’ll just have to live with it.
Harmonique131
Hello everyone.
I've just arrived at this article which contains over 500 pages!!! Wouaahh !! As it is difficult to find one's way through such a long article, what advice do you have regarding an external master clock with this R26 DAC and U18 ?
Is its contribution significant enough to justify the expense ? Which model do you recommend for the best value (under $1000) ?
Thank you very much for your help.
Sincerely to all of you from France.
sajunky
It was infighting, it is why reading this all doesn't reflect a true story. Keep it in mind while receiving conflicting responses.Hello everyone.
Harmonique131
My good mood and my goodwill for everyone is almost limitless
An audiophile for so many years, I read with interest everyone's opinion and I decide, by returning to listen to music which keeps the smile that I hold dear.
But thank you for your intervention
rodthebod
Leo Bodnar 10mhz reference clock at £165 from the UK, unbeatable value and can be improved considerably when used with better RG405 interconnects or even better still inside the R26 DAC with shorter connections, search my previous posts...Hello everyone.
Plenty on here do use external clocks and seem to think they offer a worthwhile improvement. I’m very skeptical, tests show external clocks generally reduce SNR and increase jitter, there’s a huge advantage having the clock adjacent to where it’s used, so it would have to be really bad for one provided along several feet of wire via several connections to be an improvement YMMV.
rodthebod
Hi, you're right there about distance of connection, having the external/internal clock closest to the DAC is very important from my experience. Having several feet of connection to such a critical timing device is surely bad, from common sense thinking.... no matter what cable is used. That's why having the clock inside the actual DAC is paramount.Plenty on here do use external clocks and seem to think they offer a worthwhile improvement. I’m very skeptical, tests show external clocks generally reduce SNR and increase jitter, there’s a huge advantage having the clock adjacent to where it’s used, so it would have to be really bad for one provided along several feet of wire via several connections to be an improvement YMMV.
Just FYI the Leo Bodnar has some thermal stability issues due to using a TXCO instead of OXCO like in the OCK-1.Leo Bodnar 10mhz reference clock at £165 from the UK, unbeatable value and can be improved considerably when used with better RG405 interconnects or even better still inside the R26 DAC with shorter connections, search my previous posts...
https://www.leobodnar.com/files/Informal Evaluation of a Leo Bodnar GPS Frequency Reference.pdf
sbgk
- Mar 25, 2013
I've just bought the Leo Bodnar clock and use it on the U18 with I2S to the R26, seems a nice upgrade, though still burning inHello everyone.
have tried it in both U18 and R26 and R26 only and having it on U18 seems best, not sure if it was doing anything connected to R26 as sounded the same.
Leo Bodnar are due to release an audiophile version in the coming months, better performance for more money.
wondered how Leo Bodnar compare with LHY OCK-2? I am a user of OCK-2, for one thing I know, OCK-2 provides improvement with direct connection to R26 without U18.I've just bought the Leo Bodnar clock and use it on the U18 with I2S to the R26, seems a nice upgrade, though still burning in
Total: 30 (members: 0, guests: 30)
