Is it worth to buy this app just for streaming local and Tidal? Mconnect and BubbleUPnP work for me after firmware update to 1.42, but they look terrible and outdated.
GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
- Thread starter m-i-c-k-e-y
amrutmhatre90
https://m.facebook.com/story.php?st...s5py5X9o96Xz5HWGl&id=100063769710781&sfnsn=mo
Uapp is finally capable of streaming to the gustard via upnp
Did you try this?
I am not able to see gustard in USB Player Pro, but can see in bubbleUpnP
amrutmhatre90
Not yet, doesn't workIs it worth to buy this app just for streaming local and Tidal? Mconnect and BubbleUPnP work for me after firmware update to 1.42, but they look terrible and outdated.
m-i-c-k-e-y
@camrector
https://www.musicalparadise.ca/store/index.php?route=product/product&product_id=109
It's older version was on my shortlist when shopping dacs. And then decided will not bring myself on another hole of rolling tubes..
sajunky
$1k product that use a pirated Amanero Combo384 module!@camrector
m-i-c-k-e-y
Word used is 'compatible'. The 'pirated' is a too common word in China.
Knobstler
Yeah i did but it doesnt work with the gustard or yamaha wxa 50. So farDid you try this?
sajunky
In China term piracy applies to the counterfeited product that looks identical to the original. If a copycat contains visual differences (it can be even a different font on the company logo), property owner rights cannot be enforced.Word used is 'compatible'. The 'pirated' is a too common word in China.
This is intended to protect customers -- in China. They know local law and how to deal with. No one cares about Western customers.
m-i-c-k-e-y
Been many times in China (too many to count), knockoffs (at different grades) and overproduction runs are everywhere. If nobody complains (in most cases, only western people do), no law is inforced. So no surprises there.
REXNFX
- Feb 18, 2014
All rather trivial now that China is currently posing an imminent threat to the World order.
Appreciation post. I just compared my Gustard R26 with my Modius again as I’m always wondering is all of this bs? The subjective vs objectivist arguments and so on. I first went back to modius and I was like wow the bass is impressive. Then you listen for awhile and you realize (at least with my headphones) that it’s mostly an uninteresting wall of sound with pretty good bass. I went back to the Gustard R26 and I have a new appreciation for the fast filter. It gives you back the speed you’re losing with R2R compared to delta sigma with a much better/more interesting sound than a simple delta sigma dac. It’s not even close.
rockcity007
You are comparing a $299 (Modius) DAC to a $1,649 (R26) DAC. I should hope the later would sound better.Appreciation post. I just compared my Gustard R26 with my Modius again as I’m always wondering is all of this bs? The subjective vs objectivist arguments and so on. I first went back to modius and I was like wow the bass is impressive. Then you listen for awhile and you realize (at least with my headphones) that it’s mostly an uninteresting wall of sound with pretty good bass. I went back to the Gustard R26 and I have a new appreciation for the fast filter. It gives you back the speed you’re losing with R2R compared to delta sigma with a much better/more interesting sound than a simple delta sigma dac. It’s not even close.
I know it's a bit late but I hoped it's still working. I've tried all of the upgraded versions available here (two you had posted and 1.42 ver), flashed them using balenaEtcher but I can't get Tidal Connect to work, it doesn't appear in the app. I'm using Android. I have even tried downgrading the app as you advised earlier but no success yet. Do you have any idea why it's not working?In the Roon + Tidal version, the memory consumption reaches 95% when playing Tidal. It's true that everything works, but if someone has Roon, why do they need Tidal connect. So I disabled Roon support and the memory usage is around 60%. I wrote about it in earlier posts.
If you care about Tidal and Roon here's the link. This version is official firmware 1.4 + Tidal connect without the latest updates. I wrote about it HERE.
R26 Gustarender 1v4+Tidal unofficial fix (1.02GB)
https://drive.google.com/file/d/1zBC-GeOP-aTz45yibJHwwS1CDmlLlohI/view?usp=sharing
I have now installed the old version 2.64.2 of Tidal (LINK HERE) on the latest Samsung S23+ and it works without any problems with the latest firmware 1.43. My previous versions of FW that included Tidal Connect used the same source as FW 1.43, so they should probably work as well. The only cause of problems on Android are the certificates used in newer versions of the application to securely connect to the R26. Gustard R26 is visible in the application but cannot be connected to it. If it is invisible, the only reason may be a problem with the LAN network.I know it's a bit late but I hoped it's still working. I've tried all of the upgraded versions available here (two you had posted and 1.42 ver), flashed them using balenaEtcher but I can't get Tidal Connect to work, it doesn't appear in the app. I'm using Android. I have even tried downgrading the app as you advised earlier but no success yet. Do you have any idea why it's not working?
Thanks, the combination of older app and 1.43 fw might be the only one I have not tried. I will try tomorrow. Previously I had installed 1.43 but I think my Tidal app was up to date. Btw. I have S23 base and have just updated to Android 14. Regardless of fw and app used, Gustard has never been visible in the app, which is weird because it was detected by mconnect and I could use UPnP with no issues.I have now installed the old version 2.64.2 of Tidal (LINK HERE) on the latest Samsung S23+ and it works without any problems with the latest firmware 1.43.
Total: 35 (members: 0, guests: 35)
