m-i-c-k-e-y
Roon has best user experience.
Foobar is free.
Foobar is free.
+1 for Jplay, it was the best of the UpnP apps I tried before I went to Roon. You could always buy a cheap used iphone, Google Pixel, Samsung etc and run it from there: https://jplay.app/@Kent10 take the Jplay app (an old ipad/iphone can support) and a Qobuz/Tidal account as my two cents.
No PC is necessary and it can bring a good smile to your face.
I cant find any android version for jplay?!+1 for Jplay, it was the best of the UpnP apps I tried before I went to Roon. You could always buy a cheap used iphone, Google Pixel, Samsung etc and run it from there: https://jplay.app/
They have versions for both iOS and Android, and it works really well. This makes your phone the controller but the music doesn't actually travel through the device, it's routed directly from your router to the R26. Next best thing to Roon. Worked great with Qobuz for me.
I apologize I thought they had a version for Android but maybe it’s just Windows and ios,but you could find an ipad pretty cheap and run it from there, or from your existing laptop if it's a PC.I cant find any android version for jplay?!
Bodiebill will also compare the A26 to his Merging Hapi with Ravenna.
Just imagine if the A26 outperforms the Hapi…
Yes.Was there update on this?
JPlay for iOS, and for Windows are two different players who just have the same name.I apologize I thought they had a version for Android but maybe it’s just Windows and ios
This is a big reason why you aren’t hearing a big difference from LAN.currently I have a 25m Cat6 wire running from the router across a bedroom, upstairs hallway, downstairs, entrance hall and lounge to connect up the R26
(cough)F(cough)M.......C?This is a big reason why you aren’t hearing a big difference from LAN.
26m Ethernet cable snaking through your home is not good for SQ.
Suffice it to say you are missing out on a greater improvement on sound quality until you get your foundation sorted.
I don't think so Dan they're both here: http://jplay.eu/JPlay for iOS, and for Windows are two different players who just have the same name.
There was no version of JPlay for Android.
Again with a properly set up system for LAN streaming, you would clearly see/hear the difference and understand why the LAN input is preferred for SQ without spending thousands on a DDC.well possibly, or maybe…
Both sources show the R26 at its max potential.!!![]()
