m-i-c-k-e-y
First of all congratulations! Finally on your first post!
See Page 1 (Firmware Upgrade instructions)
I'll put comparing CPL with wi-fi extender on my to-do list, don't knock it till you've tried it is a good idiom.Just one small point, having not tried a comparison myself on CPL (although I have some wall plug examples) vs wi-fi extender, of which I am a big fan. We know using FMC’s fibre modules work great to eliminate detrimental electrical noise.
So why would you use a system that travels along the mains electrical system…….
Compared to other modes of transfer of DATA, wired Ethernet is among the most silent, because it was conceived for transfers over quite long distances at times in which fiber was not widely spread. All the switches, the routers, CPL extenders, FMCs… through which the DATA travels have a built-in galvanic isolation to keep the noise floor low.I'll put comparing CPL with wi-fi extender on my to-do list, don't knock it till you've tried it is a good idiom.
They used generic access point sharing a bandwith for all users, it is why the experienced dropouts. They didn't learn a trick that they should isolate traffic. When connecting a pair of WiFi extenders to the PC, it can work as a dedicated link, no shared traffic, there will be no dropouts.WiFi extenders were not a reliable solution for audio streaming only three or four years ago. If one visits old threads on forums, he should see many reports about stuttering, and dropouts with WiFi.
Correct, if you want transmit through thick walls. It is actually a good case for a dedicated WiFi link inside the same room, very little external noise.And there are situations in which WiFi is not a workable solution for a network. For instance, we have a country house which is a very old building on three floors with in locations walls two meters thick.
But wait, two meters thick walls? There must be hidden compartments between, time to start treasure hunting.
As long my posts keep deleted, your warm welcome words will be relevant on every occasion.I can only say, welcome to this forum Mr. President
Old houses were built like that in the villages in Corsica to protect from hot and cold weather.But wait, two meters thick walls? There must be hidden compartments between, time to start treasure hunting.
Not that one, but I found a definite step forward (not subtle) with an upgrade Gustard fuse for very reasonable costDoes anyone use a Purple fuse SRX in R26?
