I will also recommend you to check CPL.
It works very well, and it's very reliable.
Thanks for the recommendation but I'm a little clueless here, what is CPL?
Absolutely. It might be ios only I can’t recall but it’s very good and I think several people here use it. I’m doing the Roon/ qobuz thing now so it’s been a while.Thanks for the recommendation. So I can use jPlay to play music via spotify?
Sweet! I have an iphone so that would be perfect for me. I'm going to keep this in mind.Absolutely. It might be ios only I can’t recall but it’s very good and I think several people here use it. I’m doing the Roon/ qobuz thing now so it’s been a while.
CPL allows streaming Ethernet through the electrical grid.Thanks for the recommendation but I'm a little clueless here, what is CPL?
It's very easy to set up. You easily can have as much Ethernet access points at your home as you want.
https://www.amazon.fr/PLP1000-100FRS-1000Mbps-filtrée-Compatible-Internet/dp/B01M1H8TIP/ref=sr_1_3?__mk_fr_FR=ÅMÅŽÕÑ&crid=2UJCU58MSIFX&keywords=ethernet+CPL+netgear&qid=1689775665&sprefix=ethernet+cpl+netgear,aps,71&sr=8-3
It brings LAN access, and internet to rooms that are not wired.So why would you use a system that travels along the mains electrical system…….
yes but why not use Wifi to a wifi extenders with a Lan port?It brings LAN access, and internet to rooms that are not wired.
You can connect to its access point a switch to which you connect your server, and the first FMC, and then you stream to the endpoint.
In my system, when I stream tracks from Qobuz, I have an identical SQ as streaming local files.
EDIT
All these devices of my signature are connected to the same audiophile DIY switch, and the CPL LAN access is also connected to it:
M1 Mac Mini → i3 NUC with GentooPlayer & Diretta Host → Sonore OpticalModule Deluxe II
Because I'm using this solution for longtime already. It's very robust, and existed as a good alternative to Ethernet wires at a time in which the WiFi extenders were not reliable enough, and were provoking dropouts from time to time.yes but why not use Wifi to a wifi extenders with a Lan port?
I wouldn’t want my Ethernet traveling over house mains.
I don't have slow internet streaming issues.I have some ethernet over powerline adaptors I used to use. Ceased using them in part because of concern re high frequency signals injected into the mains but mainly because they were quite slow in the mains wiring I tried them in.
That’s a good thing. There have been a few since launch, but looks like the gremlins have been tamedGustard sure don’t update firmware very often.
