BShaw
I understand your point barato, but......I don't know that tests always correlate with a pleasing experience. I don't need a test to tell me my pizza tastes great. Some of my components (integrated tube amp) test like hell, and sound far better to my ears than the ones I quickly turned around and dumped, the ones touted as "cleanest, lowest distortion, etc". I'm not saying I don't appreciate measurements, if I was a speaker/electronics engineer, I'd test the heck out of things, but the best designers I've known about then always test their wares subjectively, because at the end of the day they want to sell their stuff to people, not bench equipment.No, you potentially create an impedance mismatch or other high speed transmission issues that the original finished cable was tested for . It's down to luck, not quality of connectors. Thinking it sounds better is not a a real test.
But I do (believe it or not) appreciate your point. I'm going to ask my contact at Jennving about this and see what he says, would be good to know. As far as I can see, the Supra is using cheap Chinese plastic connectors, but they may just have tested a bunch to see which ones were the best match for the fewest kroners.
One more thing - I ordered the Telegartners specifically after reading over and over how well they worked with the Supra, and my guess is that just like some of the best RCA connectors, they are more "transparent" to adding resistance, due to good design. This has been my experience with KLEI Absolute Harmony RCAs, which work beautifully in both my digital cable (75 ohm) and my SE cables (90 ohm) from DAC to preamp. KLEI specifically specs them for use in both.
