Palyodgree
I have already , I have access to two models of Rockna, your welcome to pm me Ken .Waiting for your comparison with rockna and holo Dac.
Would be very nice to know what your observations have been Palyodgree, for everyone here, I'm sure....... I was tempted by the Rockna before discovering the R26.I have already , I have access to two models of Rockna, your welcome to pm me Ken .
Hi, I mean a comparison about R26 with rockna and Holo May.I have already , I have access to two models of Rockna, your welcome to pm me Ken .
Most times you get what you pay for , the Rockna WaveDream XLR and Holo Audio May are just two heavy weights in and around their price category , I owned both however they were replaced with Merason Dac 1 , slightly edged them both out in one single category, they certainly sound different the human pitch tone and timbre and sub bass notes out of the Merason is exceptional the new owner of the Holo Audio disagree that’s ok .Hi, I mean a comparison about R26 with rockna and Holo May.
Ah, okay. Otherwise it could be that you're running a DHCP server on both the modem and the router with different IP address ranges, so the streamer (or future R26) could get an IP address from the modem that your phone (with an IP address from the router in a different subnet) can't see. But since it's not working with the router, either it may well be iFi, there have been some struggles when messing with network settings. Always good to check if a PC connected that way works fine.Oops. It's an SBG6950, but I'm inclined to think it's the ZenStream causing the difficulties, and iFi's hastily cobbled together software (conjecture your honor!). Hopefully I can get CS to respond and speak with someone later today. Not connecting when I try the router either.
Since the R26 has Ethernet, Ethernet related questions are bound to come up. The question here was whether it should be possible to connect his future R26 to his modem and the Zen Stream served as a substitute for testing.You seem to be in the wrong thread. This is the R26 thread.
Thanks Alcophone, I'm hoping iFi will step up here because I know a lot of people have had connectivity issues with the ZS. As you said, the whole purpose of this exercize is to make sure the network is ready for the R26. I can't wait to just be able to plug into the Gustard, and be rid of the extraneous devices and cables!Ah, okay. Otherwise it could be that you're running a DHCP server on both the modem and the router with different IP address ranges, so the streamer (or future R26) could get an IP address from the modem that your phone (with an IP address from the router in a different subnet) can't see. But since it's not working with the router, either it may well be iFi, there have been some struggles when messing with network settings. Always good to check if a PC connected that way works fine.
Unfortunately, when it comes to clock, quality matters. I am afraid your result only proves that LHY clock is worse than the internal K2 clock of R26. Change it to a C18 and you will notice the difference. Actually C18 is the minimum one should get, anything with a lower price tag is probably worse than the original clock, playing with clock is expensive .....2) The external 10Mhz clock does improve resolution, however at the expense of musicality. I'm happier with the music without an external clock. I was using genuine Gustard cables but with a less expensive LHY clock.
Again, the quality of the I2S cable matters a lot. Your test result shows that your SPDIF cable is much better than your I2S cable. With a good I2S cable, the I2S should sound better. Soundstage of I2S should sound more 3D compared to SPDIF.3) I'm getting better music using a high quality SPDIF (rca) cable compared to the I2S which sounds very good but slightly flat in comparison.
No doubt on this, U18 + R26 will sound more detailed than LAN. The only culprit is you need quality USB and I2S cables on top of the cost of U18 and a streamer.4) I get the best results using the U18/SPDIF combination compared to LAN which has slightly more glare and the background isn't quite as black. The LAN sounds very good, just not quite as good.
What is the quality i2s you speak of?Unfortunately, when it comes to clock, quality matters. I am afraid your result only proves that LHY clock is worse than the internal K2 clock of R26. Change it to a C18 and you will notice the difference. Actually C18 is the minimum one should get, anything with a lower price tag is probably worse than the original clock, playing with clock is expensive .....
I use Phasure USB and I2S. Don't want to sound like an ad, there are probably other better USB and I2S cables on market, but costing an arm and a leg to me. Even Phasure is not cheap to me, but I just couldn't find anything cheaper that sounds the same.What is the quality i2s you speak of?
Yes, I connect the LAN direct to my Netgear router. For U18, it is laptop to U18 to R26.Did you try this yourself? What LAN set up did you use?
what USB cable are you using?
what USB cable are you using?Just to give a counter opinion, I found LAN to be better than U18.
I was also feeding U18 super clean USB source via an Allo USB Bridge, powered via LPS.
I found U18 weakest point is soundstage, LAN to me has more depth and accuracy.
And yes, I have good speakers + amp.
I have Omega Alnico hemp (more resolution than hd800) and Elekit 8600S (with vcaps + WE300b)
I beg to differ, USB cable is very important in a high end hifi CAS system, it affects substantially the musicality, soundstage, timbre on my system ..... basically everything, I can just switch USB cable to another cable and I would feel I don't want to listen to the whole system anymore.Will I admit a better USB cable than mine could make a difference, yes.
But I don't think, even close, the difference a better cable over my Belkin, would change the results of my U18 vs LAN abx.
