sajunky
How you can be so sure? In the picture below is not PCM. This method is used for decoding DSD for over 30 years. Both in ChipDACs and discrete implementations.DSD is 1bit. There is no such thing as “6bit DSD” lol.
The intermediate format, is 6bit PCM. It is an internal conversion that is at a high sample rate and noise shaped. That isn’t PCM and it isn’t DSD. There’s a continuum of intermediate formats that can work.
Look at the signal path I posted.
If DSD direct is “off” DSD is converted to PCM and sent to the R2R ladder.
If it is “on” it is sent to to the 1bit DSD DAC
For all others, advice. If you turn Direct DSD ON, make sure to resample it at least to DSD256. Otherwise there is a lot of noise coming out of bitstream decoder. I know this noise from the past.
Multibit DSD decoding became popular, as it doesn't require upsampling. It is still a native DSD decoder and use a separate set of unary resistors (not a main R2R ladder). In this mode (Direct DSD OFF), Gustard is not different to other brands like Denafrips, Audio GD.
