nicks25
Once I receive my R26, I am considering adding HQPlayer to my setup. I have been researching how to configure and am unsure of the configuration needed.
My current set up is a networked Mac Mini M1 running Roon Core. Then I have an FMC connected to an opticalRendu which is connected to my Denafrips Ares II via USB.
The opticalRendu and Denafrips will be on the sideline after I receive the R26. I will use the LAN input on the R26 fed by a new FMC.
I know that HQPlayer needs to be installed on the Mac Mini but I also see that there is a HQPlayer endpoint (NAA) required to run HQPlayer. The opticalRendu was my Roon endpoint and will no longer be in the mix. Where do I install the NAA .img file? Does it get installed on the R26?
Thanks for the help.
