SupCompracer
FWIW, per comzee's post, there is system and renderer firmware.The base system firmware, and the renderer firmware, are completely separate files, and procedures to upgrade, using different software.
system firmware =/= renderer firmware
I literally just learned that the system firmware exists today.
Again, the only place I've found a download for it is @Super Sonico post. He also has a jpeg image hosted for instructions.
If the date on display has not changed, the system firmware has not been updated.
Yes, you can update the renderer firmware to V1.3 (the latest) without updating the system firmware.
The push the button power it on to display date displays the system firmware. I don't know of any way for the R26 to display the renderer firmware version. Renderer firmware does show up in Roon as 'Gustarender-1v3' so I am guessing it may show up like that in other software used.
When flashing renderer firmware, the only way the R26 has showed up in the USB Imager flashing software for me is to have the DAC shut off in rear. Then it shows up as a 29.4GB storage device. If the R26 is in standby, no device is listed in the USBImager. That is via USB type C cable.
