fullbass
what? there are excellent high frequencies - perfect resolution, even the farthest frequencies are heard, it is clean and detailedI found the Gustard had a more rolled off treble than the DACs i tested with
Here he said he forgot to mention the Pontus 2 was the quietest of all.
Weird review.
I don't know, maybe he was just unlucky to get two defective devices. There is no noise there. I have both of these DACsR26 power supply can get a bit noisy and when changing audio formats relay sound is very audible, Schumann DAC connecting cables can be noisy when amp is on
Interesting enough, I've tried USB yesterday and I've stuttering during playback of MQA tracks! I've tried UAPP and default Tidal app. This doesn't happens with LAN input and Bubble UPnP playback, but there are not all tracks properly decoded as MQA, but PCM only.Can anyone report if this latest (15.11.2022) update has cured the stuttering problem some of us experience on Hi Res downloads?
This works. Thanks! I appreciate it.hold down the button in the middle of the scroll wheel on right hand side of unit when unit is powered off, and then press the power on button on left hand side and the firmware will display
I experience the stutter too, with hi res Qobuz tracks, always in the first 10 seconds. I'll install the Nov. update today and report back.Interesting enough, I've tried USB yesterday and I've stuttering during playback of MQA tracks! I've tried UAPP and default Tidal app. This doesn't happens with LAN input and Bubble UPnP playback, but there are not all tracks properly decoded as MQA, but PCM only.
+ For medoes anyone know how to update r26 on mac os? without a virtual machine and so on - without Win OS
I won't say it's impossible, but I tried at least 5 conversion apps and it was folly. Finally borrowed a Windows laptop and it was done in minutes. Their whole update system is bull, hard to find, hard to implement, and my pet peeve is there's no info on what's included in the updates. I just figure well, engineers are kind of like artists, good at what they do but probably need a representative to interact with the publicdoes anyone know how to update r26 on mac os? without a virtual machine and so on - without Win OS
Which firmware? There are two. Posted for all.Can someone help me with the properly firmware instal and update... the full process please.
P.m me.
I believe this is not possible, UTM works well on my MacBook M1 silicon with a small 650mb WinXP install, or using bootcamp on an older Intel Mac.does anyone know how to update r26 on mac os? without a virtual machine and so on - without Win OS
It should be possible with balena Etcher.I believe this is not possible, UTM works well on my MacBook M1 silicon with a small 650mb WinXP install, or using bootcamp on an older Intel Mac.
Yes, if you are referring to the renderer firmware 1v3, I posted earlier how I did this using Belena etcher on a Mac to reflash the internal sdcard of the R26 by removing it from the R26. The USB interface wasn't showing up when connected to my MacBook so this was a last resort. But the R26 mainboard firmware (latest to date is 15th November 2022) can only be updated using the R26 USB C port on the rear. The only firmware interface to do this at present is using an exe, which is an executable file for Windows only, no Mac version.It should be possible with balena Etcher.
