I need some help with this firmware update.
Went back and found the windows exe files posted here.
Downloaded Windows 10 to one of my Macs via bootcamp.
Ran the driver installation.
Ran the firmware updater with the R26 turned off on the front and back switches, BUT plugged into the power.
Waited for the USB-SERIAL CH341 to come up, but it never did... Tried pretty much every combination of things to make that show up but nothing. That is not listed in the COM port drop down options. I have no clue which port to try...
Alenotta
I posted way back about doing exactly this, copied below, I used UTM to run a virtual machine on my M1 MacBook as the newest Macs can't run Intel software, so no bootcamp anymore.... bummer. Look at the last points listed. Hope it helps.
Finally managed to get the latest 27th October 2022 firmware to update on the R26 using my MacBook M1 this is the actual DAC firmware (2022-10-27) not the renderer firmware (v1v3) for the streamer section of the DAC. The two are updated separately. I had to remove the 32GB Sdcard inside the R26 to get my Gustarender 1v21 then 1v3 firmware to update using my MacBook and Belena Etcher flashing software. (see earlier post #229)
I used UTM free virtual OS Mac software, I used old school Win XP 650mb only (only took minutes to load up after following a few YT tutorials). You must install the spice tools which is all available on the UTM site to get XP to work smoothly with the Mac. Most impressed with UTM as it seems to work really well on my Mac M1 if you need Winblows for stuff - i.e firmware updates! File name is: Gustard_R26_CT_221023_via_type-C.exe. Yes it updates to 27th Oct not 23rd! Just tried Win10 too, works well.
A few things that flummoxed me but eventually were sussed out:
1. You must leave the R26 off but plugged into the mains (rocker switch at rear to off), the power led will be a solid white ring as if it is on, but the blue display is blank.
2. The gobbledygook of machine code that's part of the install program instruction text and a few of the buttons is confusing, but ignore that, and the UART USB serial port CH341 is discovered by selecting it manually using the USB button bar section of UTM (top left). You have to make sure the com port that the USB cable connected to the R26 is using is selected before continuing, USB-SERIAL CH341A or similar, all other ports COM1-255 will not work.
3. In the firmware install window select the top left button marked 3. CLICK HERE to start the update, one line of machine code appears in the window, and then......
4. You must switch the R26 on from the rear rocker switch to get the firmware to actually continue to run. A progress bar runs at the bottom of the window.
5. Once the progress bar has shown complete the R26 can be checked by rebooting and holding the centre select circular button inside the ring on the right. After the R26 label shows in the display the firmware date is then shown '2022-10-27'.
(I did run the install 64bit serial driver manually before trying the update, from a zipped up file 'ch341ser driver' as part of the update package, not sure if this is necessary but it installed anyway)
Hope this helps some guys with no Winblows machine
