kameenadesi
- Feb 7, 2010
anyone get a chance to compare the m9xx and iDSD Micro?
All units shipped with v1.0 firmware. You do not need to downgrade to v0.8. To play the m9xx with iOS, plug the external power supply in first, then connect to your device with the camera connection kit. High power mode tells the device it is self powered. To check firmware version, you can press and hold the volume knob while powering on the m9xx.
I'm sorry for my simpleness. All has since been figured out. I'm boning up final parts for a review, which I intend to publish today. Being behind on iOS section is a pitiful position to be in. Thank you and sorry.
What are your thoughts on the Grace? Recommended for the price? Looking forward to your write up.
Cheers!
- Jamie
Does the 9xx support balanced cables? Does it make a difference if they don't?
Glad everything has been taken care of! I adore the ability to utilize the m9XX on the go via iPhone 6 and battery charger.
yep.
the micro is more forward sounding, and will give some life to laid back sounding cans.
the 9xx just plays it CLEAN like it is. an uncanny ability to suit many types of cans well without listening fatigue.
In case you're wondering, it's here: Grace Design x Massdrop m9XX – more mojo than Mojo. I hope to link it with a few simple RMAA measurements tomorrow or the next day or ... whenever. It's obvious that the m9XX is a phenomenal performer, even under load. It's up there with the best unloaded, but falls in a few areas VS Mojo. In almost every metric, it bests The Element.
