I finally decided to go with the Senn HD650's. Next I'll probably start working looking for a pair of Grado RS1's or something a step up around that price range.
Does anyone have a decent amp they could recommend that isn't incredibly expensive? I was looking at a decent tube amp for around $200 or a solid state at around that price. Anyone have any recommendations for less than $300?
between the two? 701's for sure, they do require a bit of a burn in however. Not for your first time buyer. I'd recommend a sennheiser because its a good start point.
Anyone have a decent amp worth mentioning that isn't insanely expensive? I had the Eddie Circuit Lunch Box shown to me and thought it sounded sweet. (literally) http://www.eddiecurrent.com/Lunch_Box.html
I have the 580 (modded with 600 grilles) and it doesn't need an amp from my X-fi. If you dare to listen to them on the go from a portable, then that's when you need an amp.
