proton007
- Feb 9, 2012
Same way nickel has a sparkly (shiny) sound.
The outer coating shouldn't have any difference, if any it's like placebo due to the colors.
lmao, so this is what you learn from the science forum huh?
I think you're confusing Placebo with Gazebo - that's when you gaze at it long enough it sound different - it's not been scientifically approved yet, but it's just a matter of time someone will make up some dumbass theory, and it'll be official...
No, not so much. Not the way you think anyway. Most of the wisdom about these is a persistent mythology - the sound science subform deals with the specifics in more detail though. I won't dwell on it though - believe what you will.
I wonder what kind of sound will silver have when cooled to superconducting levels...erm... Super Cool?
You must be new too to the forum too. It's not about silver has cool flavor on it. It's not an ingredient that gives you kool-aid taste. It doesn't work that way. It gives you detail (due to almost no signal loss and close timing) which gives you cooler, more accurate sound. Loss of accuracy results in warm sound, this is due to the loss of detail.
The differences you mention all vanish in blind testing and which metal you use, aside from the amount of resistance (which affects volume/attenuation, but not detail), is not a factor in the least.
If you want to get into t-line theory and possible ground loops, and EMF noise, we can talk. (jitter, incidentally, is only a factor in digital signals - and audible only in massively faulty quantities). The rest of it, is not based in measurable, audible reality. Psycho-acoustic phenomena, on the other hand - I'll give you.
Brass and nickel are poor conductors that introduce significant loss at the points of contact. Like I said earlier, it doesn't have the ingredient that gives you flavor.
Loss in nominal resistance is overcome by larger surface area... also - what ingredient, precisely, does an ELEMENT have (silver/gold/copper) that a different element or alloy containing them, would not - especially as regards the behavior of electricity. Something eminently testable and predictable.
Do not misunderstand the word theory. Theory means a series of principles, backed by observation which describe and predict the things we see and expect to see. Not a guess, or faith. But really - we should not go on about it here.
There are many discussions dealing with your questions in the Sound Science subforum.
Oh wee wee! bling bling! (jitter, incidentally, is only a factor in digital signals - and audible only in massively faulty quantities). The rest of it, is not based in measurable, audible reality. Psycho-acoustic phenomena, on the other hand - I'll give you.
That's right. Jitter is analog and everywhere in nature. Don't you know that when the Lynx gives birth in the wild the jitter in the vixen's contractions prior to birth give a clue about the viability of the kitten? Jitter is like gravity. It is is inherent to time-space.
