Emon
- Dec 28, 2003
I know that, I meant aluminum is aluminum when all you need is a chunk of metal with fins to absorb heat. The most you should be getting is what, 15 or 30 watts of heat? Or was it 60? All I'm saying is that I don't think you should need some super fine quality heatsink meant for military grade applications where the life of a pilot is relying on the heat dissipation of a certain circuit otherwise his guidance systems will fail. Especially if you use a little active cooling, you shouldn't have any problems at all. Besides if I were to use some cheap heatsinks, I'd be sure to carefully monitor temperature when I first turned it on. If it got out of control I'd probably junk it and buy something better. But to me the amount of money you can save is worth the risk/effort.
Anywho, that's not important. I'm researching the Dynahi right now basically to see what it would cost and how difficult it would be to build a high end amp. I'm an awfully frugle guy, I don't see the point in building several lower end amps to work up to a higher end amp and then never use the old ones. Sans making a little profit from selling the old ones perhaps. The Dynahi looked pretty simple (still does, I mean all the chassis work is no issue for me). The main thing that concerns me is the parts matching and the electronics troubleshooting. I have a lot of electronics experience, but it's mostly practical stuff, not much theory. And especially not in the more niche audio application, but I do pickup fast. Since I'm such a cheap guy I'm not planning on having a lot of upgraditis (oh, if only you could plan that :/ ) and a Dynahi might just be overkill in terms of quality anyway, when I'll be using an EMU 1212m and HD600. I don't see myself buying a $900 DAC like, ever. Anyway I think you get the idea...
