lamka
- Oct 31, 2014
i some how am not fully confident on dual board pcb
Well I have said this over and over in this thread, if you aren't confident you can handle the soldering part of the mod then don't even attempt it.
With me for example, all I needed was the diagram and the replacement cap values and I was off to the races. If you don't feel like you are somewhere in that ballpark, especially the soldering part, don't attempt it.
kindly tell me more detail about pcb i.e layers and necessary care to be taken during replacing and desoldering caps as im new to dual lay pcb
im so sory for repeating the questions:
but im not yet clear about, the purple and green replacement(placement /positioning of the replace cap is not my problems, removing/cuting out the the capacitor of the board which is not yet clear
Hi, I am a new user. Also buy the creative ZXR.
Hare also modification.
1.- According to the image need not unsolder the coupling capacitors in total are 12 and only have to weld and make a bridge diode filament.
2. The non-polar capacitor 12 uf x250v - 3 units (purple) replace the capacitors stock of the pcb.
3. The non-polar capacitor 24 uf 250v x - 2 units (green) replace the capacitors stock of the pcb.
And for replacement of operational amplifiers which to choose:
AD827SQ vs 4627-1 vs MUSES 02
AD8597 vs NE5534N vs OPA627BP
Greetings from Perú.
Germanium, You will be able to post photos of both side of the PCB as well display the final work.
Thanks.
