Stadtpirat
- Aug 3, 2014
I have a question.
Do you use the SBX Pro Studio?
I only use the EQ.
I only use the EQ.
One person used Clarity caps which are pretty costly, I am the one who used ERSE caps because they are available in the US and come at a fair price. However yes, those are the same capacitors I have installed on mine.
It is more important you understand the mod from beginning to end than it is which mylars you go with.
I don't intend this negatively at all, but if you are asking that question you may want to rethink doing this type of mod on equipment this expensive.
However I will answer your question as I was one of the first people on head-fi to perform the mod. A short takes the existing capacitor out of the circuit allowing you to use the mylars.
You can see in the OP of this thread a picture of my shorts, which are essentially just pieces of metal (I used leads from the many extra LEDs I have). Here is the picture, each location where a piece of LED lead is cut and soldered at two points corresponds to the picture and instructions you quoted above which are the stock capacitors you are taking out of the circuit. Electricity follows the path of least resistance and because of this it flows across one solder point of capacitor directly to the other, in other words the capacitor is shorted out of the circuit.
Well germanium I am sort of confused the point of using mylars if you don't short the existing ones. You would then be using the old ones in some sort of way since they are not removed from the circuit.
